F1 vs. F3 front fender supports
Is there a difference between the two? I know the F1's get set in the rear holes and the F3's in the front set of holes, but are they the same part?
Because I am putting F1 fenders on my F3 and hope they are the same support.
I am talking about the ones that go from the inner fender and arch up and around to the outer fender, just behind the headlights.
The front fender braces are all the same for F1-6. The location at the holes on the inner fender do not have to do with the fender type. That's the difference between the radiator support location of the V8 and inline 6 engines. The 6 being longer, the rad support and fender braces use the forward set of holes. There's also a different hood baffle to match. Setting everything at the forward holes will give you a lot more room for your engine transplant.
On another note! After soaking in WD-40, PB Blaster, and any concoction of the two, I FINALLY babied the door hinge bolts out! Without any breaking or stripping out the heads! I used an impact driver and hammer every night and day forever! patience paid off on those dirty little bolts! What a PITA!
Yes, they're the same F1-F6 and 48-52. There's also no LT or RT side. You just reverse it for the other side. F7-F8 and COEs had longer supports due to the larger width of the fenders. However, they were still not side specific.
mod22
16
04-08-2020 03:53 PM
ALBUQ F-1
46
06-26-2010 11:32 AM
