Injector cup replacement????? - Ford Truck Enthusiasts Forums
Old 10-10-2011, 08:18 PM
Finally Powerstrokin's Avatar
Finally Powerstrokin Finally Powerstrokin is offline
Finally Powerstrokin is starting off with a positive reputation.
Ok so I have fuel in my coolant on my 2002 F250 7.3. Everthing I have read points to bad injector cups. I am pretty decent with a wrench but by no means a diesel mechanic but after calling a local diesel shop today I am thinking of trying to tackle this myself. They said it would be between $1500 & $1800. He said he would have to pull the heads. I ask him about the tool and he said it was too hard to use in the truck and it would cost more in labor than just pulling the heads. I think he must have been talking about a slide hammer type tool. I have already looked at Riff Raffs kit and am thinking about trying this but I need to know that with these tools it is something that an averege guy with a set of wrenches and this rental tool can do with the help of all the expert guys on here. I also need to know how to test the injectors and glow plugs so that I can replace anything that needs replaced while I am in here. I love my truck and dont mind wrenching but also dont want to get in over my head.
Old 10-10-2011, 08:21 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Average guy can do it, if you have the drive to do it, it's not that bad. Sounds like you already know Clay has the best prices on them with great customer service, here is a link to Robin's writeup and he was not using Clay's newest tool IIRC Robin's Injector Cup R&R
i would send the injectors off to have them flow tested while you had them out and if you could do without for a few days, Riffraff Diesel: HEUI Flow testing
GP's are cheap enough that while you were going to be in there I would change them all personally. But you could ohm them out to verify proper resistance.
Old 10-10-2011, 08:28 PM
snakedoc's Avatar
snakedoc snakedoc is online now
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
you can do it of way less then 1500 go for it. the injectors are not that bad to do the cups cant be that bad.
Old 10-10-2011, 10:07 PM
Thanks for the confidence guys. Is there anyone that has used Clay's new version of the injector cup R&R tool that can tell me how difficult it is and approximatly how much time I can expect it to take?
Old 10-11-2011, 12:17 AM
Larry_the_handyman's Avatar
Larry_the_handyman Larry_the_handyman is offline
Larry_the_handyman is starting off with a positive reputation.
For a fellow Tarheel (and gearheads everywhere), I will do the R&R with the new tool. I can't promise it'll be as good as Robin's so I might just show the difference in the new version. I just got it in the mail today and I'll be doing the cups this weekend.
Old 10-11-2011, 12:58 AM
sledheadm7's Avatar
sledheadm7 sledheadm7 is offline
sledheadm7 is starting off with a positive reputation.
i did this project not to long ago and it took me 5 hours but i also did a oil cooler rebuild and added some other goodies while i was in there. also i am a diesel technician so prety strait forward fix for me. other then the cup removal tool there is no special tools needed. good luck hope this fixes your problems.
Old 10-11-2011, 01:40 AM
Thanks for the encouragement. I'll be happy to get it done in less than 10 hours. lol
Old 10-12-2011, 08:54 PM
Larry,
Thats awsome...I mean not that you are having problems but that you are willing to document your procedure. I will be very appreciative of any help I can get. Please give all the detail you can because I am sure I will need it. the more pics the better. Oh yea by the way how did a fellow Tar Heel end up in Sunny California anyways?...lol & thanks for the help man
Old 10-12-2011, 11:00 PM
rat49f6's Avatar
rat49f6 rat49f6 is offline
rat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to beholdrat49f6 is a splendid one to behold
i used clays tool last weekend but it removed all the rockers and rods which i wont do next time
id say a novice could do it in a day
Old 10-12-2011, 11:30 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
What were you thinking
Old 10-13-2011, 08:18 AM
brownie83's Avatar
brownie83 brownie83 is offline
brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.
Quote:
ditto....
Old 10-13-2011, 09:21 AM
rat49f6's Avatar
I was thinking I had all that off when I did mine...forgetting I did valve springs too
Old 10-13-2011, 10:10 AM
brownie83's Avatar
we all still love you...
Old 12-19-2011, 08:31 PM
Finally Purchased Clay's kit
Ok I finally got the extra money and have ordered Clay's injector cup kit with rental tool. Also bought Glow plugs to change while I am there and the Riff Raff air filter kit for my personal Christmas Present to myself. I am sooo ready to get this problem fixed I have hardley drove my truck for 2 months. You guys please wish me luck and give me any pointers that you have. I remember seeing a step by step guide to this repair on here a while back. I am going to keep looking for it but if anyone has a link please share it. I will try to take pics and give the best info I can for the next guy that may have to takle this repair.
Old 12-19-2011, 09:47 PM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Theres a link in post #2 and heres is another one.
http://www.ford-trucks.com/forums/94...placement.html
Injector Cup R&R PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 36 12-25-2016 10:42 AM
Mad as a hornet hotrodfeguy 1999 - 2003 7.3L Power Stroke Diesel 10 05-13-2016 12:25 PM
Injector cup swap, Drain coolant? Higgy 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-16-2011 01:04 AM
Afforadable injector cup tools! DZL JIM 1994.5 - 1997 7.3L Power Stroke Diesel 18 12-24-2010 08:01 AM
Injector Cup R+R info? tjbeggs 1999 - 2003 7.3L Power Stroke Diesel 48 02-11-2009 12:03 PM
Tags
40, 60l, 73, 73l, change, cup, cups, diesel, ford, injector, powerstroke, replaceing, replacement, replacing, replacment, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
