new guy has questions
Old 10-10-2011, 05:30 PM
jack.dubord's Avatar
jack.dubord
jack.dubord is offline
hi everyone im new to this site well this is the only site i have posted on ever. I have a 1997 ford f-350 PSD with the 5spd and I just had a few questions. 1 is their a way to quiet the 97 7.3l down at all. Kind of like the forum on the 99 and up ones. 2 will the turbo from the 99 and up 7.3l work on the 97 7.3l
3 will the 6 speed trany bolt to the 97 if anyone could point me in the right direction on these questions it would be great thank-you
Old 10-10-2011, 05:44 PM
arkredneck's Avatar
arkredneck
arkredneck is offline
You could out the 99 up split shot injectors in it but it will have to
Be reprogrammed to
The 99 turbo would need uppipes and turbo mount think intakes are different pretty much all different
The spd trans bolts to motor but drive shaft will have to
Be cut and other mods done
Old 10-10-2011, 06:14 PM
rideracelivemx7's Avatar
rideracelivemx7
rideracelivemx7 is offline
the superdutys used a different set up on the turbos, youd need the driverside manifold, up pipes, intake if late 99 and up and snake the intercooler if possible.
split shots like said above will help with the noise but youd need to tell your tuner about them
the 6spd is a project to get it in the OBS trucks, the zf6 has a taller face to it so it wont fit with the belly pan that we have in ours. youd need to do a little modding for it to fit, other wise, yes it would bolt up.
Old 10-10-2011, 06:19 PM
jack.dubord
so is their a better turbo or is the stock ok because i know that the 99 and up have a waste gate and the 97 do not. But im not trying to build a hot rod just a good towing vehicle. And the trany how much fab work will go into it or would a gear vender just be a better way to go. About the noise i was reading a forum on here about the fuel line quick connectors on the 99 and up sucking air into the fuel line and making it cackle a lot louder then normal is this true for my truck THANKS
Old 10-10-2011, 06:22 PM
jack.dubord
So how much better is our trucks with a intercooler added i have read that they steal boost but lower egts but our turbos only make 25 lbs on a good day
Old 10-10-2011, 06:53 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
If you want a good tow vehicle, that is the way I set mine up at a reasonable cost. Stock turbo works fine with stage one injectors. It will hit 33lbs if I really try, but I don't do that cause you're right on the 25 being about as much as you really want to push it for long. Intercooler helps a lot on temps.
Old 10-10-2011, 06:59 PM
Talyn's Avatar
Talyn
Talyn is offline
Stage 1's and an IC is a great way to go.
Our trucks just don't have the sound deadening equipment that the newer trucks have.
Old 10-10-2011, 07:01 PM
427 fordman
I should say if its like mine though, it won't be quiet.
Old 10-10-2011, 07:38 PM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
Your stock turbo is fine if you don't ever go above a stage 1 injector...
Old 10-10-2011, 08:25 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
First, WELCOME a board.
I only want to add for the noise, you can try the HPX line and add some 2stroke oil to reduce a little the noise.
Old 10-10-2011, 09:25 PM
Action4478's Avatar
Action4478
Action4478 is offline
You could always buy a 99 & up ...
Old 10-10-2011, 10:20 PM
jack.dubord
i have already on it a chip turbo back exhaust and intake. can i rebuild my factory injectors into a stage one. will my chip push them more then they should be pushed? what is this HPX line. another question what if i get that banks turbo housing that says it will make it boost at lower rpm is it really worth it. Reason why i ask all this is because i run a good grade out of my town on the way to the desert and Im pulling some real weight pluse 3000 rpm the truck is very loud and i have a new born now so just rtying to quiet it up and also get more power. ps this body style is my favorite and in cali my truck does not need to be smoged so i can run chip no cat and so on and so forth
Old 10-10-2011, 10:46 PM
95_Dually's Avatar
95_Dually
95_Dually is offline
Banks is expensive. Their kits are complete but you can put together better parts for less money.
Jim Rosewood is the best bet for injectors. He is on our site and very helpful.
Old 10-11-2011, 12:12 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
That's my wife's biggest complaint, noise! I don't want to do it but some guys gut the interior and put sound deadening stuff on the floors, etc.
Do the split shots really help, how much?
Old 10-11-2011, 06:00 AM
427 fordman
Your stock injectors can be turned into stage ones, that's what mine are. http://api.viglink.com/api/click?for...3306581271Link to rosewood. What kind of chip? It should be flashed to work with the stage ones to get the full power available. The housing will give you boost at lower rpm but higher egt's. It's not recommended for towing.
HPX is a crossover line to put between the heads to equalize the high pressure oil to the heads. Very minimal noise reduction, some say it does, some don't.
Quick Reply: new guy has questions
