ignition key alarm
I did read that you can squirt some WD40 in the key hole and then run the key back and forth until the sensor unsticks. I tried this and It didn't work however, I also read that the wire that controls the alarm is black with pink stripes. If you find this going into the back of the wiring harness under the dash you CAN cut it. I did NOT cut it, but I did pull on it a little and it ACTUALLY worked. The beeping stopped and it works like it's supposed to...
KenRebF-250
1999 to 2016 Super Duty
11-07-2016 03:28 PM
