FICM repaired, but issue - Ford Truck Enthusiasts Forums
Old 10-10-2011, 01:16 AM
GeneLaw1 GeneLaw1 is offline
GeneLaw1 is starting off with a positive reputation.
ALrighty, I finally received my repaired FICM unit and worked at putting it in the truck. I ran into an issue. The middle plug that goes into the FICM I believe is missing some kind of clip that makes it "snap" in there. So no matter how hard I pushed, it would not lock in there. I put it in there went ahead and tightened the FICM, and the truck runs great. The plug stayed in pretty good, but I took a small 100 mile journey. During this journey, the plug came out and the truck started running very rough and shaking badly. I stopped at the nearest exit and touched the second plug and the truck went back to running fine. Any fixes? Can I get this plug replaced at the Ford dealer or any other remedies you folks may know of?
Thanks!
Old 10-10-2011, 01:30 AM
_Me2_'s Avatar
_Me2_ _Me2_ is offline
_Me2_ has a good reputation on FTE._Me2_ has a good reputation on FTE.
Duct tape.
Old 10-10-2011, 01:35 AM
Quote:
Originally Posted by _Me2_ View Post
Duct tape.
LOL! Thought about that....but can it take the heat?
Old 10-10-2011, 03:17 AM
Fallguy2004's Avatar
Fallguy2004 Fallguy2004 is offline
Fallguy2004 is starting off with a positive reputation.
Nae, it wont. I seen quite a few peeps with the same problem. Some feel that the use of one or a few large zip ties will do the trick. Other than that there is a company out there who sells the replacement plugs, or a new harness from Ford.
Old 10-10-2011, 09:53 AM
NewToDiesels's Avatar
NewToDiesels NewToDiesels is offline
NewToDiesels is gaining momentum as a positive member of FTE.
I have a zip ties on mine that did the same thing.
Old 10-10-2011, 10:27 AM
Quote:
Think one from a general home improvement store (i.e. Home Depot, Lowe's, etc) will do the trick? Guess it just has to be large enough.
Ford must have made that bracket a POS, since it seems that many are also having that problem...or perhaps the heat in that area makes them brittle?
Old 10-10-2011, 11:01 AM
Probably heat. You know how plastic is. I have two zip ties (standard stuff from Lowe's) together to make it longer so it will wrap around the FICM. I have 4 ties total making a two-tie (for length) 'strap' on both sides of the connector. My plan is to get the larger industrial strength ones, but these have been fine for the last 6 weeks since I installed them.
Old 10-10-2011, 11:02 AM
Piolet's Avatar
Piolet Piolet is offline
Piolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to behold
I also did the ziptie repair.
The one on the left in the first pic below would slip off so it now has an additional ziptie linking the two to help keep them in place.
Old 10-10-2011, 11:11 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
They have really cheesy clips on those plugs. One of mine has a broken clip, both the second clip holds it well. I wish they had used the cam-style clip like on the PCM plugs.
Old 10-10-2011, 12:24 PM
I always thought I was the only one that was heavy handed and broke it... I feel so much better now
Old 10-10-2011, 12:32 PM
Piolet's Avatar
If something can be broken, stripped, snapped, pinched or spilt when it shouldn't be ... them I'm your man.
I also seem to have a knack of picking up the wrong part at the store when ever there is a choice of more than one. - Sometimes I just buy 1 of every type because I live so damn far from everywhere
Old 10-10-2011, 02:37 PM
My MAN! You would not believe how much better I feel after starting this thread, lol...I thought I was the only bonehead that broke one, haha. Didnt help that all the ladies around me kind of scoffed when I told them I was going to replace the FICM myself (in lieu of dealing with the blue headed rapist to the tune of $1300)....now I can come away knowing that this was at least somewhat common, lol
Old 10-10-2011, 03:16 PM
The zip tie gang - we need a logo.
Old 10-10-2011, 07:33 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
LOL--you're not alone. Add me to the list. I absolutely HATE taking a FICM out and I've done it several times. It never seems to get easier.
Old 10-10-2011, 08:38 PM
Quote:
Yes, does it really have to be so tight in there? Especially trying to access the bolts in the rear of it...and I have small hands and arms!
Late 04 F250 6.0 No Start Dogman_528 6.0L Power Stroke Diesel 15 11-20-2015 10:15 AM
FICM help crfpoor 6.0L Power Stroke Diesel 5 09-03-2015 01:05 PM
FICM is gone... onequicksportster 6.0L Power Stroke Diesel 12 03-03-2015 11:37 PM
2007 6.0 no power to ficm softpickle 6.0L Power Stroke Diesel 8 02-15-2015 12:58 AM
Ficm issue? Chief Many Inches 6.0L Power Stroke Diesel 12 01-04-2015 06:43 PM
Tags
2003, 60, alliant, ap0018, atlanta, clips, f250, ficm, ford, home, improvement, lowes, powered, repair, snap, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
