2005 F250 6.0L Transmission Wont Move In Reverse - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-09-2011, 10:50 PM
Shooter Mike Shooter Mike is offline
Shooter Mike is starting off with a positive reputation.
165,000 and no real issues until today. I'll try to describe this as best as I can. Imagine backing up a hill, and your tires spin, then catch, spin, then catch. That's what it's like when I put my truck in reverse. Almost like a surge. My truck has been parked on a hill, with the parking brake set firmly before putting it in park. I back up the hill (my driveway). Today, I was coming home, and attempted to back all the way up the driveway, but the truck wouldn't do it. Ended up putting it in 4-wheel-low, and "surged" right up. I later checked the transmission fluid, and it was, surprisingly, low. I added 2 1/2 quarts. Mind you, I drain my pan every other oil change and replace that fluid, and my filters have less than 15,000 miles on them. As the day goes on, the truck shifts into reverse, with normal RPM guage change, but doesn't move backwards even with revving the engine, at first. After some steady acceleration, it creeps backwards. Forward is fine, although, it does seem as if I have to give it a little more pedal than what I think I should. It rolls fine, but if I didn't know better, I'd say it almost feels like it's being "held back" just a little when going forward. It rolls fine, so I know it's not a stuck brake or something like that. The situation with reverse has me quite concerned though - this is my snow plow truck and we're not too far out from the season beginning. Hopefully I can get this figured out quickly, and somewhat inexpensively.
Old 10-10-2011, 06:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
Quickly, yes. Inexpensively, I doubt it.
The slip and grab causes damage to the clutch. Holding the accelerator down to get the truck to creep finished the job of destroying the clutch. I'm as sure as I can be without actually looking at the truck that it is as good as it will get. It's only going to get worse and worse. The sooner you get the trans out and rebuilt the less damaged/destroyed parts will need to be replaced.
Old 10-10-2011, 07:10 AM
Thanks Mark. Ballpark cost?
Old 10-10-2011, 09:36 AM
$2000-$5000
Old 10-10-2011, 10:02 AM
Thanks AAMCO quoted me $3100
Tranny trouble? Hoehandle 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 01-28-2016 03:42 PM
2000 Excursion will not roll backwards - Rear Diff or Trans? NCPirate Excursion - King of SUVs 12 04-06-2015 12:35 PM
Wheels lock up in reverse gear everytime I press clutch pedal ced715 Ranger & B-Series 11 07-05-2011 02:04 PM
01 Expedition won't drive in gear cmjboyer 1997-2006 Expedition & Navigator 1 03-17-2011 03:53 PM
Can anyone hlep me out. Auto Transmission Won't Go! bobbyrjw 1999 - 2003 7.3L Power Stroke Diesel 15 10-18-2010 02:50 PM
Tags
1987, 2005, 54, engine, f150, f250, f550, ford, liter, quarts, reverse, stuck, total, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
