1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
blower blowing with key off
Old 10-10-2011, 08:55 AM
lidmaker's Avatar
lidmaker
lidmaker is offline
Was sitting at home yesterday when the horn on my 1999 F-350 SD starts going off, the truck was unlocked and no one had pushed the panic button on the remote. So I open the door the horn stops but as I get in I notice the blower is on and blowing with the key in my pocket I can stop the blower by simple turning it off and it has all the speeds for the fan. Shut the door and the horn starts up again. It has been raining and am wondering if the moisture has anything to do with it. Or what could have possible shorted out. Any help would be great.
Old 10-10-2011, 09:03 AM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
Look for water dripping down onto the fuse panel and GEM module under the dash, left side. It is a somewhat common problem for the windshield to leak and allow water in there, causing corrosion and shorts. You may have to remove the fuse box and look at the back of it for corrosion.
Old 10-10-2011, 09:16 AM
lidmaker's Avatar
lidmaker
lidmaker is offline
That makes sense. I will give that a look Thanks
masond
04-05-2011 01:35 PM
ztodd377
16
03-19-2011 06:27 AM
Boss_hoss
12-02-2010 02:20 PM
tonystillwell
11-26-2010 08:32 AM
astro99sd
01-11-2009 02:26 AM
Quick Reply: blower blowing with key off
