95 f-150 radio wires that dont match diagrams? - Ford Truck Enthusiasts Forums
Old 10-09-2011, 07:02 PM
icelander_34 icelander_34 is offline
icelander_34 is starting off with a positive reputation.
1995 Ford F150 Factory Stereo Wire Color Diagram?
I'm trying to wire up an old Deck I found laying around up to the truck..however the diagrams I've found are as follows and barely any match what I have in my harness......
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
I can't find the green/yellow constance 12v wire? I have the following power wires from the factory harness
Power
2 - Black/Green
1 - Green/Black
1 - Yellow/Black
1 - Blue/Pink
1 - Orange/Black
1 - Black
Anyone come across this before? I also have a blue/white wire, a brown or tannish/yellow and a grey/pink that arent mentioned.
Thanks in advance!
Old 10-09-2011, 07:08 PM
Also, have a green/purple
Old 10-11-2011, 12:01 PM
ItsMREMT's Avatar
ItsMREMT ItsMREMT is offline
ItsMREMT is gaining momentum as a positive member of FTE.ItsMREMT is gaining momentum as a positive member of FTE.
hey are you trying to splice your oem harness to plug in this radio or did you buy a radio harness adapter?
Old 10-12-2011, 01:24 PM
The truck didnt have the factory harness in it when i bought it so im trying to splice the new radio in. Its just strange to me that only about half of the wires match the standard wire diagram....And i really dont want to run it to the fusebox or the battery. I have thought about pulling all the panels and checking the wires to all four speakers but dont want to if i dont have to.
Old 10-12-2011, 02:20 PM
ItsMREMT's Avatar
I would get a voltage meter and test the unknown wires
Old 10-31-2011, 02:34 PM
Don S.'s Avatar
Don S. Don S. is offline
Don S. is starting off with a positive reputation.
Quote:
Where are you getting the color code from? A Haynes or chiltons?
Old 02-17-2014, 08:13 PM
bustedford95 bustedford95 is offline
bustedford95 is starting off with a positive reputation.
Any luck? I have the same problem.
Old 02-18-2014, 04:28 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Get your wire diagrams from the auto zone website....
Old 03-19-2014, 05:07 PM
jasefm jasefm is offline
jasefm is starting off with a positive reputation.
1995 f150 i6 radio wiring?
1995 f150 i6 radio wires do not match any online diagrams. The colors are no where close.
Help!
Old 03-20-2014, 07:34 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
You best resort at this point might be a printed factory EVTM specific to your year and model.
I can't find anything reasonable for your '95 F150 but will check with two other sellers I've bought from in the past---they might have one or more hiding in their back rooms.
Will update as I know more.
HTH
97 F150 radio wiring diagram help! BAJACRAZY32 1997 - 2003 F150 1 11-11-2016 11:40 PM
HELP - sport trac wiring doesn't match diagrams Glenn Nall Explorer, Sport Trac, Mountaineer & Aviator 7 02-20-2015 01:24 PM
PLEASE HELP '95 F150 bustedford95 1987 - 1996 F150 & Larger F-Series Trucks 4 02-17-2014 09:09 PM
Stereo wiring harness colors Airslot Excursion - King of SUVs 6 12-01-2013 07:18 PM
simple newbie wiring question klx90 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-27-2011 06:51 PM
Tags
95, 97, back, diagram, dont, duty, f150, ford, light, match, radio, schematic, schematics, speakers, super, truck, wiers, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
