Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-09-2011, 01:40 PM
96speed 96speed is offline
Garage is empty, add now
96speed is starting off with a positive reputation.
OD Toggle or Tow/Haul?
I'm considering a late model Expedition to replace my 2003 F150, but I have a question about the transmission:
Do the 2007+ have a tow/haul mode or do they simply have an OD toggle button?
  #2 (permalink)
Old 10-09-2011, 03:38 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
Only a O/D toggle
With 6 speed tranny though, really doesnt need tow/haul. My F-250 has that. It doesn't lock out the O/D. Just adjusts the shift points and let you rev higher in gears
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 10-09-2011, 03:46 PM
Thanks for the info.
When is a good instance where you would want to lock out OD? Excessive inclines where the trans is constantly down shifting? It seems like the 6spd would shift more often anyway since there is an extra O/D gear.
  #4 (permalink)
Old 10-09-2011, 05:36 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
to be honest, you really only would need to lock out O/D when you are towing and the trans starts to shift more frequently. up to that point, I always leave O/D on
the shifting creates heat, and heat kills transmissions. so why not leave it alone and let her pick her own gear until she needs some help?
__________________
  #5 (permalink)
Old 10-09-2011, 08:19 PM
Johnny Law Johnny Law is offline
Johnny Law is starting off with a positive reputation.
Wait a minute. The 2011 (6 speed) I have has a Tow/Haul button on the Shift Knob. It does more than lock out overdrive. Which really it doesn't. Apparently, according to the owners manual, there are sensors that monitor the attitude of the truck so that when it is going up. It will shift out of OD and stay there prior to hitting the hill. Also on the decent, and it works pretty well, when you hit the breaks it will down shift. You can then remove your foot from the brake and let the engine keep speed. Just as you would manually.
Not sure when this was added but obviously different than the older ones.
Johnny
  #6 (permalink)
Old 10-10-2011, 06:01 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
No "tow/haul" on my '07 XLT. Nor have I ever locked out OD for other than a short experiment. All it does is run the truck at nearly 3000 rpm when it could be loafing along at 1800 rpm.
The transmission shifts frequently between 5th and 6th with an occasional drop to 4th towing my 5000 pound camper across the mountains on the PA turnpike, but the transmission temperature stays under 190°F. Heck my Expedition will downshift to 5th on these same grades without the trailer.
The uber-low 1st gear on the 6-speed seems made for towing.
I spent the extra $300 on the HD Tow option for this truck. And 5000 is well under the 9000 pound maximum towing capacity. Pushing the high end will probably be different.
-- Chuck
Tags
2008, 2009, 2010, 5th, 6th, add, expedition, explorer, f150, f250, foed, ford, haul, lockout, mode, od, switch, tow, towhaul, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
