AOD or E40D How do you tell the difference? - Ford Truck Enthusiasts Forums
Old 10-09-2011, 01:25 PM
92 Red Flareside's Avatar
92 Red Flareside 92 Red Flareside is offline
92 Red Flareside is starting off with a positive reputation.
Hey guys I have a 92 F-150 that was manufactured in 91. I have been told that some of the early 92's had AOD's before ford made the swap to E40D. Don't know if thats right thats just what I've been told. The reason I'm asking is because I'm thinking about a mass air conversion and it makes a big difference. Any help is appreciated.
Old 10-09-2011, 01:37 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Look at the number of pan bolts and shape:
Old 10-09-2011, 01:39 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Look at your gear selector.
P R N (D) 2 1 - E4OD (1992+ will have OD cancel switch on column shifter) (1989-1991, OD cancel switch on dash, right side of steering column)
P R N (D) D 1 - AOD
P R N D 2 1 - C6
Or you can count the pan bolts.
17 pan bolts - C6
14 pan bolts - AOD
20 pan bolts - E4OD
Old 10-09-2011, 01:42 PM
hammerhead90's Avatar
hammerhead90 hammerhead90 is offline
hammerhead90 is gaining momentum as a positive member of FTE.hammerhead90 is gaining momentum as a positive member of FTE.
Easiest way is to climb under and count the pan bolts
http://www.fordification.com/tech/im...-transID08.gif
Old 10-09-2011, 02:59 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Well, if you can't figure it out after the previous posts, there's not much hope for you.
Jason
Old 10-09-2011, 09:16 PM
Thanks for all the info guys. Unfortunately it's the E40D! Just my luck.
Old 10-09-2011, 09:42 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
Quote:
The E4OD is a good trans, and pretty tough, but when they mess up its pricey.
If my AOD gives out I can rebuild it for around $600 or less
Old 10-09-2011, 09:45 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Ive had an AOD and E4OD.
My E4OD can be a PITA at times but I will take it any day over my AOD.
Old 10-09-2011, 10:01 PM
The problem with the E4OD is it shifts WAY to soft! Any tranny that shifts really ssoft like that will never live long.
That's why if I have to have an auto, it MUST be a C6, I will refuse anything else! The hell with OD!
Old 10-09-2011, 10:25 PM
86F150302's Avatar
Quote:
Just get a Punisher valvebody and make the E4OD shift like it should.
Guy on NLOC had 188k miles on his and it also made 843hp and 936 torque. He had a Punisher valvebody.
Old 10-09-2011, 10:49 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
Mine lived a long unhappy life (200k miles) being constantly neglected. Take some care of her and she'll take care of you.
Old 10-10-2011, 09:23 AM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
I am just curious on what makes you say that. In your opinion, what makes the E4OD so much better than the AOD?
Old 10-10-2011, 10:17 AM
Encho's Avatar
For one, the AOD is rated for 750lb/ft of torque, the E4OD is rated for 1000lb/ft.
Old 10-10-2011, 11:11 AM
SCRebel's Avatar
I adjusted my TV cable to hold the gear longer and shift stiffer
Old 10-10-2011, 11:14 AM
SCRebel's Avatar
Quote:
Originally Posted by Encho View Post
For one, the AOD is rate for 750lb/ft of torque, the E4OD is rated for 1000lb/ft.
And on the AOD if the TV cable isn't adjusted right you'll burn the AOD up.
Benefit to the AOD is that it will bolt up to any small block ford, and Lokar sells kits to put the AOD behind a Carburated engine. (If you don't have the carb kickdown bar for the AOD)
ACCEL CABLE DIFFERENCE 86fn150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 01-10-2015 02:43 AM
92 f150 4.9 E4OD Need a wiring harness for trans! Phillip Reeves 1987 - 1996 F150 & Larger F-Series Trucks 8 02-08-2012 06:18 PM
E40d - AOD Transfer case SCRMFRMHLTPS 1978 - 1996 Big Bronco 14 11-17-2010 12:53 AM
1995 F150 4X4 transmission ID subsailor 1987 - 1996 F150 & Larger F-Series Trucks 5 10-27-2010 08:38 PM
M5OD anygood behind a 351w? 1986FordF150I300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 33 06-19-2010 07:25 PM
Tags
1990, 1992, 4x4, 50, aod, c6, column, e4od, f150, lariat, oil, pan, serie, steering, tranny, transmission, v8, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
