Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-09-2011, 10:17 AM
mginc mginc is offline
Garage is empty, add now
mginc is starting off with a positive reputation.
07 Navigator Suspension Off msg - Plz help
hey guys,
on my 07 Navigator 4x4 ultimate, i see air suspension off msg and the rear of the truck has dropped few inches.
can somebody please help me turn this back on, i read somewhere u can turn the suspention back on from the back kick panel but cant seem to find it.
please help..
  #2 (permalink)
Old 10-09-2011, 10:42 AM
glruff's Avatar
glruff glruff is online now
2005 Ford Ranger
glruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputationglruff has a superb reputation
Can you access the option through the vehicle message system?
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4, Innovative Diesel Tunes/10 Expedition EL LTD/12 Explorer LTD EB/13 Platinum F150 EB
  #3 (permalink)
Old 10-09-2011, 11:06 AM
mmm access it how?? i have options and rest button but nothing to turn it back on. may be i am doing it wrong
  #4 (permalink)
Old 10-09-2011, 11:13 AM
glruff's Avatar
2005 Ford Ranger
When you get to that section on your instrument control message center, hit RESET to turn it back on.
Do you have your manual? If not check the Ford site for a copy of the manual here,,, https://owner.ford.com/servlet/Conte...OwnerGuidePage
Do you see three buttons on the dash anywhere which shows? INFO - SETUP - RESET
From the manual:
AIR SUSPENSION SYSTEM (IF EQUIPPED)
The air suspension system is designed to improve ride, handling and
general vehicle performance during:
• Certain road conditions
• Steering maneuvers
• Braking
• Acceleration
This system keeps the rear of your vehicle at a constant level by
automatically adding air or releasing air from the springs. If you exceed
the load limit, the rear air suspension may not operate. The air
suspension system will stay active for 40 minutes after the ignition is
turned off to accommodate any load changes. (The air compressor may
run when the vehicle is off; this is normal.)
The air suspension system can be enabled or disabled through the
message center. Refer to Message center in the Driver Controls chapter.
If the system is off, the rear air suspension will not operate and will not
raise (pump) or lower (vent) while the vehicle is not moving. However, if
the system determines that the vehicle is low or high and needs to make
a height adjustment while driving at speeds above 15 mph (24 km/h), the
system will pump or vent as required. Normal vehicle operation does not
require any action by the driver.
On vehicles equipped with air suspension, turn the air
suspension and the ignition switch off prior to jacking, hoisting
or towing your vehicle.
2007 Expedition (exd)
Owners Guide (post-2002-fmt)
USA (fus)
Driving
263
__________________
  #5 (permalink)
Old 10-09-2011, 11:37 AM
glruff's Avatar
2005 Ford Ranger
Also from the manual:
Air Suspension
Before disabling the air suspension, make sure the liftgate and liftgate
glass are in the closed position.
1. To disable/enable the air
suspension feature with the vehicle
in P (Park), select this function
from the SETUP control for the
current display mode.[/left][/left]
2. Press the RESET control to turn the air suspension OFF or ON.
__________________
  #6 (permalink)
Old 10-09-2011, 12:01 PM
hey bro, i have three buttons INFO SETUP REST
i followed your instructions and the air suspension was turned off, so first i hit setup button till i got to air suspension menu , it was off so i hit reset and the brackets came over to ON. it says air suspension on when i do the system check, but my navi is still dropped from the back you think something might have gone wrong with the suspention?
  #7 (permalink)
Old 10-09-2011, 12:09 PM
glruff's Avatar
2005 Ford Ranger
Hmmm don't know about that, is it give you any codes? With the air system ON, if there is a problem with it, you probably will get a warning light.
The driver manual may help to determine whether there are issues with the nav system.
Explain about your navi "is still dropped from the back"?
__________________
  #8 (permalink)
Old 10-09-2011, 12:15 PM
nop no warrnings, or error codes, and navi is so dropped that i cannot even drive it.
  #9 (permalink)
Old 10-09-2011, 12:53 PM
glruff's Avatar
2005 Ford Ranger
Quote:
Please explain, not sure I understand your statement.
After you changed the setting did you start your truck?
This should turn on the air compressor I do believe. If not, then you need a dealer to look at this for you.
__________________
  #10 (permalink)
Old 10-09-2011, 12:56 PM
i mean the navigator is so much dropped, that if i drive, it feels like i am hitting the tires.
  #11 (permalink)
Old 10-09-2011, 12:59 PM
glruff's Avatar
2005 Ford Ranger
Can you hear the air compressor come on?
If not, then check for blown fuses for the compressor. If you cannot find then a trip to the dealer is in order.
__________________
  #12 (permalink)
Old 10-09-2011, 01:08 PM
nop, cannot hear compressor, bro could you tell me where to look for these fuses? under the hood?
  #13 (permalink)
Old 10-09-2011, 01:26 PM
glruff's Avatar
2005 Ford Ranger
Do you have the owners manual?
See pages 288 to 295
__________________
  #14 (permalink)
Old 10-10-2011, 12:28 AM
i found this on page 261 in the online owners manual http://content.screencast.com/users/...6/00000760.png
just need to figure out where this box is located.
Tags
2003, 2007, 20111201, air, airbag, expedition, f250, gallery, navigator, off, reset, suspended, suspension, sususpension, switch, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
