2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
OD Toggle or Tow/Haul?
Old 10-09-2011, 01:40 PM
96speed's Avatar
96speed
96speed is offline
I'm considering a late model Expedition to replace my 2003 F150, but I have a question about the transmission:
Do the 2007+ have a tow/haul mode or do they simply have an OD toggle button?
Old 10-09-2011, 03:38 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
Only a O/D toggle
With 6 speed tranny though, really doesnt need tow/haul. My F-250 has that. It doesn't lock out the O/D. Just adjusts the shift points and let you rev higher in gears
Old 10-09-2011, 03:46 PM
96speed's Avatar
96speed
96speed is offline
Thanks for the info.
When is a good instance where you would want to lock out OD? Excessive inclines where the trans is constantly down shifting? It seems like the 6spd would shift more often anyway since there is an extra O/D gear.
Old 10-09-2011, 05:36 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
to be honest, you really only would need to lock out O/D when you are towing and the trans starts to shift more frequently. up to that point, I always leave O/D on
the shifting creates heat, and heat kills transmissions. so why not leave it alone and let her pick her own gear until she needs some help?
Old 10-09-2011, 08:19 PM
Johnny Law's Avatar
Johnny Law
Johnny Law is offline
Wait a minute. The 2011 (6 speed) I have has a Tow/Haul button on the Shift ****. It does more than lock out overdrive. Which really it doesn't. Apparently, according to the owners manual, there are sensors that monitor the attitude of the truck so that when it is going up. It will shift out of OD and stay there prior to hitting the hill. Also on the decent, and it works pretty well, when you hit the breaks it will down shift. You can then remove your foot from the brake and let the engine keep speed. Just as you would manually.
Not sure when this was added but obviously different than the older ones.
Johnny
Old 10-10-2011, 06:01 AM
chuck s's Avatar
chuck s
chuck s is offline
No "tow/haul" on my '07 XLT. Nor have I ever locked out OD for other than a short experiment. All it does is run the truck at nearly 3000 rpm when it could be loafing along at 1800 rpm.
The transmission shifts frequently between 5th and 6th with an occasional drop to 4th towing my 5000 pound camper across the mountains on the PA turnpike, but the transmission temperature stays under 190°F. Heck my Expedition will downshift to 5th on these same grades without the trailer.
The uber-low 1st gear on the 6-speed seems made for towing.
I spent the extra $300 on the HD Tow option for this truck. And 5000 is well under the 9000 pound maximum towing capacity. Pushing the high end will probably be different.
-- Chuck
scrooge
2009 - 2014 F150
01-08-2016 02:16 PM
rlt7272
03-06-2013 05:19 PM
boots1219
1999 to 2016 Super Duty
02-10-2010 03:59 PM
tbax46
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
22
08-28-2005 12:45 AM
fredjeep
Ford vs The Competition
07-16-2004 06:25 PM
Quick Reply: OD Toggle or Tow/Haul?
