F350 4x4 front axle removal - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-09-2011, 08:35 AM
Jungle4jim2 Jungle4jim2 is offline
Jungle4jim2 is starting off with a positive reputation.
I have an 06 F350 4x4 and have it torn down to replace the axle joint drivers side. Is there a trick (ie clip, roll pin) to removing it from the housing? It seems pretty happy in there...... I cant find an exploded view on line any where... Thanks- Jim
Old 10-09-2011, 12:44 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
The axle just pops out of the carrier , get a big screwdriver or pry bar and pop it out . There is a great step by step ball joint replacement that shows in pics how to get the axle out, just do a search. On mine The seal that is in the knuckle was keeping me from getting the axle out so I had to pound out the seal from the back side then the axle came right out.
Old 10-10-2011, 08:55 AM
KSRick KSRick is offline
KSRick is starting off with a positive reputation.
Try http://www.ford-trucks.com/forums/35...ll-joints.html
Good step by step instructions with pictures.
Rick
1994 f150 4x4 5 speed manual 302 jimgould New Member Introductions 1 06-08-2015 12:05 PM
Excursion axle seal jim4366 Excursion - King of SUVs 5 03-04-2011 10:59 PM
strange axle code door tag baileybilt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 07-17-2008 04:58 AM
Axle code Jim McCarty 1999 - 2003 7.3L Power Stroke Diesel 12 07-22-2003 06:33 PM
Ford 9" Jim_1 Offroad & 4x4 3 01-05-2000 07:35 PM
Tags
05, 1999, 2002, 4x4, axel, axle, details, exploded, expoded, f350, ford, front, photos, removal, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
