Has anyone done true duals on their truck
I'm redoing some things on my 95 F150 with the 302 auto LWB, while I change the timing chain. I was thinking of going ahead and putting true dual exhaust on it. I know you can't run it down the left because of the gas tanks, but has anybody tried to run it down the rightside. If anyone has done it, if you don't mind please post some pic so I have an idea of what it looks like. Thanks
True duals, long tube headers, mandrel bent sections from Summit Racing, H-pipe, with Flowmasters. I had to route around the transfer case also.
90degree mandrel bends going around the T-case
H-pipe just past the clamp, mufflers flipped on sides
From there the right pipe uses a 45degree mandrel to exit behind the wheel on the right, the left pipe uses a couple mandrel sections for axle clearance and then a 45 cutting it over and out behind the left wheel
davewave649
22
12-17-2011 12:45 AM
Jason Lewis
98
07-04-2011 08:35 PM
bobwires
21
06-09-2010 10:29 PM
95F350XL
03-21-2010 10:21 PM
