glasspacks: where to start? - Ford Truck Enthusiasts Forums
Old 10-08-2011, 11:09 PM
XxWINxX94 XxWINxX94 is offline
XxWINxX94 is starting off with a positive reputation.
Hello everyone.
Truck is a '78 F150 Ranger 4x4 with 4speed and 400 motor. Current exhaust setup is regular dual pipes going to 2 midas mufflers then regular tail pipes coming out behind the back wheels. I would just put the proposed glasspacks in place of the 2 midas mufflers i have on there now.
Would like to switch over to glasspacks for reduced back pressure, better sound, louder sound, and just an overall change for the truck.
I do not want flow master or anything like that, I'm just about set on glasspacks.
I do need some good advice from the experts though. Whoever has glasspacks, where is a good place to buy them, or look at them? What brands are good or bad? How would you reccomend putting them in?
I have a pretty good budget for them so I don't want something really dinky, I would prefer something a little more serious, but not overboard on price.
Thanks for the help!
Old 10-08-2011, 11:11 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
My advice on glasspacks is to stick with steel can mufflers.
They blow out and are too loud in the first place.
jmo, based on having both.
Old 10-08-2011, 11:39 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
I concur with your opinion about glasspacks. That's precisely why I opted for Moroso Spiral Flows - no fiberglass packing, compact, and they are fully welded steel cans... $54 each at Jeg's. They have a nice burble. Here are pics of the fab work:
Painted w/ a prototype cardboard exhaust tip... eventually made the exhaust tip outta sheet metal. It exits in front forward of the right rear tire.
Old 10-09-2011, 01:14 AM
Fordfreek!'s Avatar
Fordfreek! Fordfreek! is offline
Fordfreek! is starting off with a positive reputation.
I'll be the odd man out here....
I put glasspacks on my truck about a month ago. I had a set-up similar to the one you described, dual pipes going into 2 off brand cheapo quiet quiet mufflers. I put 22 inch thrush glasspacks in place of the off brand mufflers - great sound, not too loud at all, very quiet at idle and as long as you run pipe out from under the truck it's pretty quiet inside the cab as well. The longer the glasspack, the quieter they will be. Only con is, like mentioned above the fiberglass packing will eventually blow out and they will be louder. Mine are fully welded steel, and they have a really good sound, deep and mellow, not really loud and raspy at all. I paid 17 bucks each for them and I couldn't be happier with the outcome although it is only a temporary setup. I'll throw up an exhaust clip for you tomorrow.
Old 10-09-2011, 01:18 AM
73f250highboy's Avatar
73f250highboy 73f250highboy is offline
73f250highboy has a good reputation on FTE.73f250highboy has a good reputation on FTE.
I am getting those same mufflers. What size are yours? Do you have a video of it running?
Old 10-09-2011, 01:38 AM
weez440's Avatar
weez440 weez440 is offline
weez440 is starting off with a positive reputation.
i have a 400 in mine with hooker headers and exhaust and i went with 12 inch cherry bomb glasspacks. at first they were really loud but now they actually got quiet once they broke in. they are quiet in cruising speed and idle speed but once you crack it down they cackle. i am very happy as of right now with them cause you can have a conversation and if you want to rap them out all you have to do is hit the accelerator a little and let ppl know where you are at. btw mine exit behind the wheels.
Old 10-09-2011, 02:14 AM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
They aren't glass packs but I would check out some Hooker Aero-Chamber mufflers. They are a straight thru design, they sound great and are built like a tank! They aren't real cheap but they also aren't the most expensive either.
Hooker Aero Chamber Mufflers - SummitRacing.com
Hooker Headers Aero Chamber Mufflers - JEGS
But if you want glass packs they are pretty much all the same. Cherry bomb, Thrush, Flowtech Purple Hornies or Red Hots, etc. Just order the length and pipe size you want.
Mufflers - Stainless Steel Mufflers - Exhaust Mufflers
Old 10-09-2011, 03:34 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
my dads 76 (w/460) has dual 2 1/2" and each has a really long patriot glasspack, they are like 36" long and it has a really nice, low, quiet tone. but like you said they too will blow out, but so far they have at least 5 years on them!
HIO Silver- got any installed pics?
Old 10-09-2011, 03:44 AM
CHELLIE's Avatar
CHELLIE CHELLIE is offline
CHELLIE is gaining momentum as a positive member of FTE.
Turbo mufflers, Cheap and sound great just my 2 cents worth
Dynomax Super Turbo Mufflers , they have fiberglass in them
Dynomax Super Turbo Mufflers - JEGS
Old 10-09-2011, 10:11 AM
HIO Silver's Avatar
Quote:
They're 2.5-inch. Sorry, I don't own a video camera.
Quote:
Sure. Here ya go:
Prototype, mock-up, and final version of the tip:
Old 10-09-2011, 11:03 AM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
If you do go the glasspack route i'd go with a perforated core and not a louvered core, the perforated core doesn't blow out the fiberglass packing like a louvered core does, and they're more free flowing as well, i'd recommend 24"-30" in length, it's not too short as to sound obnoxious but you'll still get that classic glasspack "rumble".
Old 10-09-2011, 02:39 PM
Goliath1975's Avatar
Goliath1975 Goliath1975 is offline
Goliath1975 is starting off with a positive reputation.
I have headers and Cherry Bombs on my 360, exiting in front of the rear tires. I threw it together without a lot of research and it was cheap and sounds mean. If I were to do it again, I think I'd spend the extra money on Flowmasters so I don't have to shout at people across the cab. Also, my glasspacks are about 20" after the headers. I'm sure where you mount them makes a difference too.
Old 10-09-2011, 03:35 PM
HIO Silver's Avatar
To reduce the amount of interior noise, locate the mufflers/glasspacks behind the cab to reduce sound vibration and, perhaps more importantly, the exhaust tips need to project beyond the body line.
Dumping the exhaust down to the ground under the cab or bed results in the sound waves being reflected back up into the bed and actually results in slightly higher noise levels.
Old 10-12-2011, 05:51 PM
dakonthemountain dakonthemountain is offline
dakonthemountain is starting off with a positive reputation.
Well I'm another person that likes Glasspacks! I have dual 44" (yes, 44") Blue Streak on burt and I love the sound! He's had them for 27k miles also and no blowouts our problems so far... Of course now that he is for sale they will blow as soon as someone test drives him!
Go with what ya want I say! ... but always get opinions and ideas...
Good luck!
Dak
adding glasspacks question 5.8l choate 1987 - 1996 F150 & Larger F-Series Trucks 7 06-19-2014 12:48 PM
dual glasspacks vs. straight pipe offroad17 2004 - 2008 F150 16 10-12-2008 08:18 PM
thrush glasspacks anygood? maddmudder13 Exhaust Systems 10 07-30-2006 12:11 PM
Glasspack v. Muffler homer4.2 3.8 & 4.2L V6 9 08-28-2004 02:58 PM
Glasspack on V-10 tallman Modular V10 (6.8l) 9 08-01-2004 05:57 PM
Tags
73, blow, bomb, cherry, difference, expedition, fiberglass, glass, glasspack, glasspacks, hornies, idi, louder, make, muffler, packs, purple, thrush, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
