Anyone use Timbrens with no gap?
I know people sometimes want softer rides in "unloaded" conditions but I'm really OK if it doesn't ride like a caddy,,,its a truck.
That said, have any of you installed Timbrens in the rear right on the block ears with no gap? Here's my issue: I'd like the truck bed to sit level (is about 1" difference with 1/2 tank of gas and its a new truck) and I'd like to raise it about and inch. So, I'm thinking of using the Timbrens with the shim spacer to basically stabilize the rear and raise it a touch.
I typically carry construction equipment in the bed and occasionally tow a trailer with a bobcat or other similar stuff so I am interested in the benefit of the load boosters for their intended purpose as well.
Anyone have this setup?
I have them Cause I carry a sander in the winter...I have an inch I think between..
They work great..Should have them in there stock..I wouldn't do what you want I don't think you'll get good results IMO..I think you'll get some bouncing feeling...I get that when I have say 600 lbs in there..Kinda bounces off the stops..Try it!!!
Dick
Dick
2009kr
1999 to 2016 Super Duty
24
07-08-2016 11:17 AM
