New Edge CTS 3.0 Update - Ford Truck Enthusiasts Forums
Old 10-08-2011, 11:45 AM
nghtrgr's Avatar
nghtrgr nghtrgr is offline
nghtrgr is gaining momentum as a positive member of FTE.
Got an email today from them plugged it in and updated.....this is the list of PIDs that it says it will track now for 6.0L
Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed (03-04), Engine Coolant Temp, Engine Load, Engine Oil Pressure, Engine Oil Temp, Engine RPM, Engine Run Time, FICM Voltage, Gear with TCL, ICP Pressure, Injector Pulse Width, Intake Air Temp, Mass Air Flow, Mileage Coach, MPG Instant, MPG Average, TCC Duty Cycle, Time 0-60, Time 1/4 mile, Trans Temp, Turbo Boost, Vehicle Speed (04-07), Variable Geometry Turbo Duty Cycle
Old 10-09-2011, 08:07 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 10-09-2011, 04:26 PM
Sullid01's Avatar
Sullid01 Sullid01 is offline
Sullid01 has a good reputation on FTE.Sullid01 has a good reputation on FTE.
I installed it yesterday - mostly a bunch of mileage PIDs - haven't had a chance to see if they are helpful or accurate. No major changes really. - Dan
Old 10-09-2011, 04:40 PM
nghtrgr's Avatar
Yep that's about what I got out of it...it still states oil pressure but since there is no factory sensor we outta luck there
What should my gauges be telling me? Woody79 1999 - 2003 7.3L Power Stroke Diesel 6 11-09-2013 01:26 PM
Finalizing maintenance and modifcation list before starting next project the_auto_tech 6.0L Power Stroke Diesel 43 10-13-2013 10:33 PM
Reviewing a few things before moving on - the_auto_tech 6.0L Power Stroke Diesel 49 08-02-2013 10:38 PM
Edge Insight CTS update Piolet 6.0L Power Stroke Diesel 41 08-24-2011 05:36 PM
No Power, no boost psi MikeyKazoo 6.0L Power Stroke Diesel 5 04-11-2011 02:08 PM
Tags
30, cts, edge, login, minimum, review, update, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
