2004 F250 2WD Leveling kit
This is the kit that I used. I'm very happy with the quality.
You will most likely need dual axis camber bushings to get the alignment within spec, But the alignment shop can also install them for you. (thats what I did)
FORD F250 F350 SUPER DUTY 2WD 2" LEVELING LIFT KIT FB2 | eBay
here is the thread I started, and it has a few pics.
Page 2 has some close ups.
https://www.ford-trucks.com/forums/1...kit-is-on.html
I've heard that with time and the elements the plastic/nylon ones will lose their shape and sag just enough to screw up your alignment. Thats why I went with the aluminum.
