Modular V10 (6.8l)
Used V10 engine $950
Old 10-07-2011, 09:15 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
How's this sound on price? 85K miles
2000 excursion V10
What to look for is this scenario? Take as much of the computer/wiring as possible?
Thx.
Old 10-07-2011, 09:43 PM
dkf's Avatar
dkf
dkf is offline
For one find out how long it was sitting out like in the pics with the oil fill cap off, therm housing, TB exposed for all the world to see and etc. Would be nice to hear it run but I'm sure that ain't happening. If you can get the wiring yeah ****** it up before Jimbob runs over it with the lawnmower.
Old 10-08-2011, 08:39 AM
topscrt's Avatar
topscrt
topscrt is offline
try to turn over the motor if you can . turning the crank pulley. look for any exhaust port or exhaust manifold with excessive oil or antifreeze marks on any cylinder
Old 10-08-2011, 03:09 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
i'd be nervous of buying a used engine from a "rolled" over vehicle without hearing the engine run..
if the engine was still running while upside down, that cant have been healthy for the bottomout...
i'd pass unless you heard it run.
Old 10-08-2011, 03:14 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Problems I see: open TB, open thermo housing and open oil fill. Owner will say that all 3 were only uncovered for the pic and I'd say he is lying. It is only worth a core the way I see it.
You also want oil pressure numbers and compression on all cylinders. Any good scrap yard measures all those things and will give you the info, as well as covers up all the openings to the engine.
Old 10-09-2011, 02:57 PM
Daz00Excursion's Avatar
Daz00Excursion
Daz00Excursion is offline
My Backpack Gots Jets
any used engine is a gamble. i would go over it with a fine tooth comb. compression check..see if you pull a valve cover off and check it..better if you have one of those inspection video camera thingys so you can check the valves and insides of the engine. see if you turn it over easily.also would be better if they provided a warranty. if no warranty i would walk away. if its a private party i would walk away.
case in point. when i was looking for an LQ9 donor for my 00 Silverado. found one on craigslist from private party. everything seemed kosher till i got it home and opened up the bottom end. number 4 bearing was shot to poop and it had bad valves on passenger side head. the guy said it was pulled from a 47k mileage 06 escalade. it was more like 130k mile motor. luckily the guy worked with me and refunded me half of my money and gave me the 4L80E trans and and SS rearend. it really helps to have a buddy who is an IRS agent and threatening the guy to have my buddy "look" into his records lol...anywho morale of the story is..check..double check and triple check it over before you shell out the money.
Grand Pops always use to say" if its too good to be true..it usually is a lemon"
Old 10-09-2011, 03:08 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Thanks Guys for all the info/advice. Quite a difference in price, but this one likely can be run before purchase.
ford v10 motor
Old 10-09-2011, 03:11 PM
Daz00Excursion
ford v10 motor
that is a good buy. considering a used reman engine cost $3300 bucks stock. Jasper Engines is a good place to get work done.
3cv
05-10-2015 06:21 AM
nicebenz68
Ford Truck Parts for Sale
03-27-2012 09:28 PM
WyoCobra
Modular V10 (6.8l)
35
02-26-2012 07:07 PM
scubadog
1999 to 2016 Super Duty
08-24-2009 07:19 PM
X20004x4x10
07-21-2004 10:55 PM
Quick Reply: Used V10 engine $950
