How much shock travel? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-07-2011, 08:31 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
The roads are getting worse in this drought and I need new shocks. How much travel up and down should I be looking for? My problem is I've got a 2wd with a leveling kit. While everyone else seems to be able to use the standard shocks, my truck sitting on level ground measures 14 1/2" from center of shock bolt to the top mounting plate. The standard Bilstein shock for 2wd measures 15" fully extended. I know I hit several dips and bumps in the road that cause my front end to raise up 1/2" or more above stock while driving.
Currently I've got some shocks I picked up from 4 wheel parts for a 2wd with a leveling kit, but they are pathetic. Bilstein offers a 5100 series shock for a 4" lift with dimensions of 12.17" - 18.98". Is roughly 2 1/4" of compression enough before a shock bottoms out, or do I need more? I'm thinking I might want a little more compression, but don't know how much I should be looking for. Any advice is appreciated.
Old 10-08-2011, 01:34 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Hmmm, I have those same Bilsteins on my truck, with 2" kit too. Now you have me wondering.
Stewart
Old 10-08-2011, 02:10 AM
kawcrasher's Avatar
kawcrasher kawcrasher is offline
kawcrasher has a good reputation on FTE.kawcrasher has a good reputation on FTE.
The best thing to do is pull off a shock, flex it out and measure. Add at least an inch to the full droop number and subtract the whole thickness of the bump stop, plus an inch from the compressed number. It may be hard to a 2wd heavy truck in this position, though.
Old 10-08-2011, 08:55 AM
F350-6's Avatar
Quote:
I don't think I'll be trying that by myself. Maybe I'll just measure the distance to the bump stop and add an inch to figure the amount of compression from ride height. I can double check again after jacking up the wheel I guess.
Stewart, throw a tape measure on yours and let me know what your measurement comes up to. I did replace my springs shortly before doing the leveling kit so maybe that's why I have an issue and no one else seems to.
Old 10-08-2011, 10:47 AM
F350-6's Avatar
Well 2 5/8" from the I beam to the bump stop so I guess those shocks won't work. Anyone have any other suggestions on shocks?
Old 10-08-2011, 01:08 PM
Vinny Mastrodomenico's Avatar
Vinny Mastrodomenico Vinny Mastrodomenico is offline
Vinny Mastrodomenico is starting off with a positive reputation.
Chris maybe you can use this adapter.
Amazon.com: Explorer Pro Comp 690001 Stem Mount to Eyelet Shock Adapter: Automotive
It will allow you to run eyelet shocks and work with the stem setup for 2wd. I would think with just the 2" spacer, you can use the adapter and use front shocks of your choice for a non lifted 4wd f350.
Old 10-08-2011, 01:28 PM
kawcrasher's Avatar
Quote:
For droop just jack it up by the frame. Are 2wd SD's twin I-beam. I have never seen one up close, not many around here. If so you would to leave shock on and just take a guess on how much more down travel you need/want.
When you measure up travel pretend that bump stop isn't there. It will completely flatten out with a good hit.
Old 10-08-2011, 01:59 PM
Stewart_H's Avatar
Will do.
I'm at my brothers in Folsom right now, heading out for a day hike. Tomorrow is racing at Fred's Truck Drags at Sacramento Raceway. I'll be back home late Sunday so I'll try and get that measurment for you Monday.
Stewart
Old 10-08-2011, 08:05 PM
F350-6's Avatar
Very interesting idea, but unfortunately it won't work. The stock shocks we pulled off my wifes 4 x 4 measure about 15" compressed. That would mean after losing another 1 1/2" or so for the bracket the 4wd shocks would be fully compressed all the time. Too bad, because we've got a great set of shocks sitting here not being used and the brackets are cheap enough.
Thanks for the thought.
Yes, twin I beam. I'm not as worried about the droop as the compression. Seems the shortest shocks seem to be for a 4" lift which are just too long I'm afraid.
And the bump stops are pretty stout and thick. Based on what I've seen from the clear spots left on the I beams when I had worn out springs, I don't think they'll compress more than half way, but point taken.
I'm beginning to think I need to cut the bottom shock mount off and weld another one a little higher up.
Old 10-10-2011, 05:07 PM
Rancho Suspension's Avatar
Rancho Suspension Rancho Suspension is offline
PREMIUM SPONSOR
Rancho Suspension has a very good reputation on FTE.Rancho Suspension has a very good reputation on FTE.Rancho Suspension has a very good reputation on FTE.Rancho Suspension has a very good reputation on FTE.
Got your note,
For your application* we have for the front
RS999264XL Comp. 15.625 Ext. 24.375 Travel 8.750
RS999261XL Comp. 19.25 Ext. 32.875 Travel 13.625
I would want you to PM to make sure the mounting points are correct as I went off a 4WD applications.
__________________
Follow us on Facebook!
https://www.facebook.com/ranchosuspension
If I missed a PM or conversation, e-mail me support@gorancho.com
Old 10-10-2011, 06:52 PM
F350-6's Avatar
Quote:
Originally Posted by Rancho Suspension View Post
Got your note,
2wd is different. It's got the screw shaft on top and standard eyelet on bottom. Problem is sitting on level ground measuring the shock it measures 14 1/2", so a compressed length of 15" or more won't work. I need something that is in the 12" to 17" range I think. Anyway to find a part from another application that would hold the heavy diesel motor in a one ton truck?
Thanks for the input.
Old 10-10-2011, 06:54 PM
PREMIUM SPONSOR
I think I can, I think I can.
I will start on this project in the AM with some numbers for you.
__________________
Old 10-10-2011, 06:57 PM
F350-6's Avatar
Perfect. I get a lot of windshield time, so please give me the numbers for the premium model.
Old 10-11-2011, 11:13 AM
PREMIUM SPONSOR
Red face
PM incoming, a couple of more questions/clarifications.
__________________
Old 10-11-2011, 06:26 PM
Stewart_H's Avatar
Chris, I called and left you a message, and as well, sent you a PM.
Lemme know if you need anything else.
Stewart
Help with suspension - 2011 F-250 PokerMunkee 1999 to 2016 Super Duty 39 03-21-2016 01:30 AM
Rear shock help please! xtal_01 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-11-2014 10:41 PM
The saga of the new shocks... Rifboy 2009 - 2014 F150 9 05-09-2014 08:48 PM
How to choose a leveling kit Bobbys Big Red Rig 1999 to 2016 Super Duty 0 09-28-2012 10:24 PM
King Coilovers installed w/picture Von-Overkill 6.7L Power Stroke Diesel 5 10-12-2011 06:45 PM
Tags
1995, 2006, 4, f150, f350, have, jumping, lift, needed, proper, rancho, shock, shocks, standard, travel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
