Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 10-07-2011, 05:02 PM
myblkex's Avatar
myblkex myblkex is offline
Garage is empty, add now
myblkex is gaining momentum as a positive member of FTE.
Battery Light is ON -- now what ??
I started driving home from work today and about 15 miles from home my Red Battery light on the Dash lit. I got home and started the truck 2 or three times after having the doors open for a while. No problems with lights or radio etc...
Anyone know if that means my Alternator is about to go ? I'm thinkingof bringing the truck to Autozone to have them check the Alternator. If I need one they have a Gold Duralast lifetime warranty one in stock.
Anyone have any advice :
1 - Sounds like alternator most likely ? I got a new Deka Battery less than 12 months ago and never had it go down.
2 - Is Gold Duralast any good ?
3 - How hard is it to DIY replace ?
Thanks !!
-- I get to add this to my a/c blowing out of defrost that I still haven't got to fix list ! lol
__________________
2000 V10 Excursion 4x4 w/ '05 Conversion
ProComp Lift with 315's, HID's, Cowl Hood
20% tint, Helliwig Rear Sway, XM Satellite
5 Star'd Tune *****
  #2 (permalink)
Old 10-07-2011, 05:19 PM
Fishing_Uncle Fishing_Uncle is offline
2000 Ford Excursion
Fishing_Uncle has a good reputation on FTE.Fishing_Uncle has a good reputation on FTE.Fishing_Uncle has a good reputation on FTE.
Offhand it does sound like a charging issue. Do you have a multimeter lying around the house? If so you can do a quick check by first checking the battery voltage with the engine off ( somewhere around 11.80 or so if I remember correctly ). Then recheck with the vehicle running and it should be somewhere near 14v or so.
Edit: I would first make sure that your connections are clean and tight since you mentioned a new battery in the last year or so.
  #3 (permalink)
Old 10-07-2011, 06:11 PM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
2000 Ford Excursion
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
Quote:
If it turns out to be the ALT, it's easy to replace with only a few tools. Get a replacement ALT with a lifetime warranty.
Everything you need is in this post: http://www.ford-trucks.com/forums/99...lternator.html
__________________
Sean
2000 Excursion XLT V10 4x4 170K, front V's, rear mod'd C's,, 315's, winch bumpers F/R, Viair system, Piaa lighting, Hellwig rear, dual Optimas, oily K&N, RedHeaded, scratchy paint, love taps at each corner.
Join the So Cal chapter here
  #4 (permalink)
Old 10-07-2011, 06:23 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Keep an eye on your battery. Chances are, it wasn't getting a good charge from your dying alternator.
__________________
2002 Excursion XLT V10 2WD 4.30 Limited Slip
Bone stock with restrictive Y-pipe and Michelin AT/2
Front Hitch Reciver, Rear Hellwig Sway Bar 7643
  #5 (permalink)
Old 10-10-2011, 11:57 AM
myblkex's Avatar
UPDATE --
Had a VERY BUSY weekend with daughters birthday and more stuff - but I got a few minutes to do a little work.
Tightened the battery cables ( the negative was just a tad loose - so i retightened it ).
Then I took it around town for a while. The battery light stays lit , but when driving it uphill and trying to hold 2,500 - 3000 rpm the lights flickers off now ( instead of solid lit ) and after about 20 seconds of driving it at 3k rpms it finally goes off completely. The battery stays off for a few minutes but then returns after coasting around or not hitting that high an rpm for such a sustained period of time.
I also tested the battery with the engine running and shows about 11.x volts, best i could tell without finding the good digital readout voltmeter. Giving it gas to 3,000 rpms while in park still does not cause the battery reading to fluctuate...
Still sounds like the alternator may not be putting enough ? Should I put in a new alternator ? I'm looking at an Durastar Gold from autozone if I need one.
__________________
5 Star'd Tune *****
  #6 (permalink)
Old 10-10-2011, 12:42 PM
Joemz9's Avatar
Joemz9 Joemz9 is offline
Joemz9 is starting off with a positive reputation.
I would say take it to a local parts like autozone and such, they can test your ALT, cause it sounds like it is going out!
  #7 (permalink)
Old 10-10-2011, 02:56 PM
2000 Ford Excursion
Agreed, the voltage does seem very low with the engine running. It is also possible that the battery is now pretty well taxed if both the alternator was failing and you had a weak connection.
Best to run it to the local auto and have them test them both really quick.
  #8 (permalink)
Old 10-10-2011, 03:10 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is online now
2001 Ford Excursion
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Replace the alternator.
Duralast Gold alternators haven't given me a problem on the cars I've installed them on.
__________________
Excursion & 6.7 Forum Mod Death Row Inmate #21
2001 X PSD Limited, 203*, HD4R100, GEARHEAD TUNES, MBRP, Hpx, Frx, T500, RAS, Cass Stage I's, 38R w/HFO, M208, 6.0 tc/ic, CFM+, 6 inch lift, 4.10 Gears, Coolant Filter, CAT ELC, AE, Afe 6637, Riffraff Boots. Too much to list, but FAR from stock FTE Guidelines
Quote:
Originally Posted by Toreador_Diesel
Ford didn't call it a "Powerstroke Diesel" becuase they thought it would be a cute name to give a diesel engine...
  #9 (permalink)
Old 10-10-2011, 04:09 PM
offroad_x's Avatar
offroad_x offroad_x is offline
offroad_x is gaining momentum as a positive member of FTE.
I definitely sounds like the alternator is going. The voltage should be around 14.5 all the time, regardless of engine speed.
A dead cell in the battery can cause that too...but then you would have starting issues. So, I would think it is the alternator. It can be tested at any parts store.
__________________
2001 Excursion limited 4x4 7.3 4R100 4 inch lift BFG AT/KO 35" DPTuner 60T/80E/120R Detroit Truetrac rear/ LS front 4inch Magnaflow muffler, DIY Tymar w/ Airaid RAS DCPower 190 Amp alternator dual optimas , Flex-a-lite electric fans, KC Daylighters, Baja Magamule rack cal4wheel membership
  #10 (permalink)
Old 10-11-2011, 07:05 PM
myblkex's Avatar
Picked up a new Duralast Gold 130amp alternator at Autozone last night. Before heading out to work this morning I popped the hood and pulled the old one. Pretty straight forward - luckily nothing was seized or rusted through.
Drove to work and back about 45 miles roundtrip and no longer have any battery light. Looks like we're all good
Thanks again guys for all your help !
__________________
5 Star'd Tune *****
  #11 (permalink)
Old 10-13-2011, 03:26 PM
19-kilo's Avatar
19-kilo 19-kilo is offline
2001 Ford Excursion
19-kilo is starting off with a positive reputation.
So now that his issue has been solved... hope you all can help me. My red battery light comes on randomly while driving.
The batteries are less than a year old and were tested last month (good). I checked to make sure the battery cables are tight...
I just replaced my alternator (thanks ED) with a Ford Remanufactured one. When the light came on I had 14.3 volts driving down the interstate. The light went off and on randomly during my 3 hr trip. During idle now with the light off I am getting 13.6 volts and 12.5 with the engine off... my red battery light comes on randomly while driving and stays on for a while and then turns off randomly.
Ideas?
__________________
2001 4x4 Forged 7.3L "Zombie Slayer" aka the "Big Bus": DP tuner - 60T 80E 120R, MBRP 4", RRD 6637, Isspro EV2 - EGT Trans temp Boost with AIH delete, Bilsteins, HyperFlex Swaybar and endlink bushings, Rancho SS, FRx, HPX
2011 Raptor SuperCab 6.2L
  #12 (permalink)
Old 10-13-2011, 04:11 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Check your body ground.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #13 (permalink)
Old 10-13-2011, 04:15 PM
19-kilo's Avatar
2001 Ford Excursion
Quote:
Stewart
I think I know what you mean (the ground cable that goes from the passenger battery to the body fender)... but can you elaborate on location/plural?
__________________
  #14 (permalink)
Old 10-13-2011, 04:44 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Yeah, to ground from the battery to the body.
Also, make sure your terminals and clamps are clean and "fresh". I use Noalox compound between the terminal post and clamps to protect the metal and enhance conductivity. Noalox Anti-Oxidant Compound
I'd also make sure your cables are all up to spec and in good working order. Make sure the connection where the clamps attach to the cable wires are in good order.
Stewart
__________________
  #15 (permalink)
Old 10-14-2011, 10:11 AM
19-kilo's Avatar
2001 Ford Excursion
Drove around some more yesterday:
Watched the volts move based on RPM. If there were no electrical accessories on, at idle the volts would be 13.9. But the second you turn on the AC or fan the volts drop to 12.5 at idle. If you drive and get the RPM up above 1000 the volts would increase to 13.6.
Is it normal to see the volts vary with RMP and accessory usage so much?
I remember that when I installed the alternator at first the volts would be a healthy 14.5... but cant get that high now.
__________________
Tags
350, 73l, 99, altnewbattery, battery, dash, driving, duty, excursion, f150, ford, light, lit, stays, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
