'49 F1 Family Project - Ford Truck Enthusiasts Forums
Old 10-07-2011, 05:49 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
After much searching and researching we finally found our new family project. It was near Redding, CA and apparently has been a central California truck for many decades and has been parked in a garage on blocks since 1992. Originally a 6 cylinder, it now has a Merc Flathead V8 that turns over but supposedly needed a valve job, which is why it was parked years ago. My wife and I drove down to pick it up yesterday and I was utterly amazed at the lack of rust. The steel bed floor, cab floor, cab corners, door bottoms, fenders and everything else is COMPLETELY rust free! This morning I got her all cleaned out and parked in the garage to keep her out of the weather forever. The trim and broken windows are all in the bed. Our game plan is to get her running and stopping so we can do some summer cruises next year. We are on a very tight budget, so appearance is not a concern right now. If I can get the Flathead running I will leave it, otherwise I will swap it for a running 6 or 8. I found the frame VIN, but the glove box and firewall tags are long gone. Fortunately the title matches the frame. So far I haven't been able to find the firewall stampings that tell assembly plant, etc.
Since I have been viewing the Fat Fender forum for a few years I have gleaned tons of good info from the rest of you. However, there are a few questions I have.
  • What is the lever on the floor in front of the driver side of the seat? It looks like a later model fuel tank selector.
  • How do you open the cowl vent? I'm assuming there's a cable somewhere.
  • Will a C6 fit without modding the cab floor? I have a line on a 302 with a C6 that I could get a good deal on, but if a C4 will fit better I will do that.
  • Is there a difference in F1 tailgates between years? Our truck came with 2, plus we picked up a 3rd for $25. They all look the same to me.
I appreciate your help and I am sure I will have many more questions as we go. Here's some pics:
Old 10-07-2011, 06:02 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51 SCRAPHEAP51 is offline
SCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to behold
cool truck, Looks like in great condition, Cant really help with your questions but I am sure someone will shortly. Great find, Have fun!
Old 10-07-2011, 06:20 PM
badger_hound's Avatar
badger_hound badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
Congratulations on your find. It looks real clean.
I don't know what that little lever is for - neither of my trucks have one...
Old 10-07-2011, 06:29 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
Looks identical to a fuel selector switch in an old jeep - for running two fuel tanks. Did you look to see if there was a 2nd tank or plumbing for an in bed tank or anything? I have never seen a "stock" truck with it, so I would bet it was an add on.
Old 10-07-2011, 06:36 PM
Quote:
I haven't looked yet, but I think you are right.
Oh, I also found the lever to open the cowl vent! Woo-Hoo!
Is there another filler tube poking out or hiding somewhere? I think the panel truck gas tank normally mounts under the driver's side...
http://www.ford-trucks.com/forums/93...rame-info.html
Old 10-07-2011, 06:46 PM
Quote:
Originally Posted by badger_hound View Post
Is there another filler tube poking out or hiding somewhere? I think the panel truck gas tanks normally mount under the driver's side...
It could be. I'll have to crawl under and see.
Here's a pic of my wifey in the monkey face.
And myself:
Old 10-07-2011, 08:23 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
That's one heck of a start
If they were all that nice no one would be here
Old 10-07-2011, 09:53 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
  • Is there a difference in F1 tailgates between years? Our truck came with 2, plus we picked up a 3rd for $25. They all look the same to me.c
The lever on the floor is not stock. Look for a second fuel tank or plumbing for one like suggested. Handle underneath/behind the instrument panel will open the cowl when you push it forward (but you already found it). Can't help you with the C6. Yes, there is a slightly difference between 48-50 and 51-52 tailgates. 48-50 tailgates had the chain latch bracket inside the top rail. 51-52 had them below the rail.
This is a 48-50 F1 tailgate. Note the chain latch position in the top rail.
This is a 51-52 tailgate. Note the chain latch positioned below the top rail.
You have a fine looking start. If you're in need of missing parts, let me know. I have a ton of parts to get rid of.
Old 10-07-2011, 10:03 PM
Thanks for the tailgate info. Now I know we have 3 48-50 tailgates. I crawled underneath and found that the valve has cut fuel lines underneath, but I don't see that it hooked into the tank to fuel pump line.
I will be taking stock of our extra parts and missing parts, so I may check to see what you have.
Old 10-07-2011, 10:55 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Wink
If you need any parts numbers, post -up your requests,and NumberDummy will surely chime in.He's helpful that way.
Old 10-07-2011, 11:20 PM
49fordF-1's Avatar
49fordF-1 49fordF-1 is offline
49fordF-1 is starting off with a positive reputation.
Alas, I think I can actually answer a question for someone! VERY sweet ride btw! looks to be in great condition. I bought my 49 F-1 just about a year ago equiped with a 302 and C6 trans. It does fit without and alterations to the cab. the bell housing however on mine was dang near touching the center trans cover, which does fit with the C6 trans, just need to cut a new hole for the shifter. On mine there was plenty of room between the waterpump and the radiator so I'm not sure why they put it sitting so far back unless it was a center of gravity thing. Beats me.... Mine had an electic fan on the front of the radiator, again leaving plenty of room between the front of the engine and the radiator. It was all taken apart when I bought it so the first thing I did was put it back together to make sure it ran, then pulled the engine and trans in one piece and on craigslist it went. BTW, when I bought it it was advertised as a 351W, I soon found out it was a 302 but didn't matter too much since I was selling it. I now have a sweet 1950 8BA with a 3 spd. trans waiting for a transplant. Can't wait to get that baby in there! I have never seen that lever on the floor either, I've had a 48 F-1 with a flattie 6 as well, no wierd lever on the floor. Love your "new" truck, have a blast with it!
Old 10-07-2011, 11:25 PM
49fordF-1's Avatar
Oh yeah.... love the 3 "bumper srickers" ya got on your posting page.
Old 10-07-2011, 11:27 PM
Quote:
Originally Posted by 49fordF-1 View Post
Alas, I think I can actually answer a question for someone! VERY sweet ride btw! looks to be in great condition. I bought my 49 F-1 just about a year ago equiped with a 302 and C6 trans. It does fit without and alterations to the cab. the bell housing however on mine was dang near touching the center trans cover, which does fit with the C6 trans, just need to cut a new hole for the shifter....
Thanks so much for the info. Right now I am leaning toward selling the Merc and going with a 302/Auto just because I may be able to do it for little or no cash and I grew up on 289/302's. The auto would just make cruizin and parades easier.
By the way, does anyone know if the leaf springs would interchange from a '52 F1 to my '49? I found a broken leaf up front, but I have a line on all running gear and suspension from a '52.
Thanks!
Old 10-07-2011, 11:33 PM
49fordF-1's Avatar
The heart of my 49 "Bessie"....
Pictures from Woodies on the Wharf 2011 badger_hound 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 08-27-2011 04:46 PM
56 F100 Progress gquinn8516 1948 - 1956 F1, F100 & Larger F-Series Trucks 104 12-02-2010 08:16 AM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 01:02 PM
mother nature 1 us 0 460429_freak Missouri Chapter 3 05-14-2009 02:56 PM
dirty/salty trucks i eat hybrids Excursion - King of SUVs 37 01-12-2008 08:07 PM
Tags
1949, 1950, 390, 4852, 49, cylinder, f1, ford, fte, install, motor, mounts, restoration, thermostat, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
