'49 F1 Family Project
#106
Next year I will pull the bed and clean and paint the frame and possibly flip the axle over springs to drop the rear ride height.
The year after I will pull the cab and do the frame under it.
Eventually we'll put in a V8 (289,302, 351) with automatic and do the body work, but this is at least a 10 year project so just getting it running is our biggest goal.
#107
The reasons for doing it in stages every winter are budget and I have 4 daughters that I need to teach about all the systems involved in a vehicle (hydraulic, mechanical, etc.) so the more we work on the truck the more they will know first hand.
#108
#110
#111
They may not fit because the 52 front engine mounts are angled slightly differently and, thus, are mounted in a wider position than the 48-51 mounts on the front crossmember. To mount the 52 front engine mounts on the 48-51 frame, will require replacement of the front crossmember as well (if I remember correctly).
#112
I also got the front end off the frame so the frame is stripped from the cab forward.
I also tore apart the front springs and removed 5 of the 8 leafs, keeping the two longest and the second shortest, making it similar to the way my 2000 F250 leafs are. If the ride is too soft I can always add leafs back in.
As you can see, I do need new spring eye bushings.
I am now in the process of taking the best components from my original front axle and the donor '52 front axle to make the best one.
I am slowly making progress, but it sure is fun!
#113
#114
I am still doing well as far as budget goes. Last week I sold my extra-extra (#3) tailgate for $100, and we only paid $25 for it.
#115
#117
Krylon Satin Black, which is what I have been using since I was a kid in the '70's. The frame and under parts are Krylon Semi-flat black, which is durable and I have a bunch of cans that have been following me around for about 15 years!
#118
Well it has been a while since I had anything to put on here, but I finally finished running new brake lines, installing the rebuilt master cylinder and cleaning/painting the steering box and column.
Here's the master cylinder. Yes, I buffed the brass distribution block even though nobody will ever see it. It is the detail work that soothes me the most. I also soldered new terminals on the wires because I don't ever want to be under there trying to find a bad connection. The hole in the floor board is from a fuel selector valve that I removed.
I decided to do away with the bracket that the brake line and front brake hoses meet. I drilled out the upper bracket mounting hole and will run the brake hose into it for a cleaner look. This is the driver side front frame rail.
Here's the steering box. I think it had about 5 pounds of greasy crud on it. I did run the mounting bolts from the outside of the frame for a cleaner look. They were the other way from the factory. I just have to get some cotter pins in there.
I've been doing a little each day and WOW does it feel good to spend some time working on her.
The best part is when I'm laying under the truck trying to figure out how I want to run brake lines and one of my daughters starts asking what different parts are.
Next will be re-bushing my front springs so I can get the front axle back in. I ordered the bushings from Mac's and I think they are sending them by pack mule because they won't be here for another week! Oh well, there is still plenty of cleaning and painting to do on the front axle.
#120
It won't be like that when it is hooked up, it is just waiting for the hose. The hose will be hard mounted to the frame so there won't be any movement. Once I get the front axle cleaned up and mounted I will put up some more pics so you can see what I mean.
