'49 F1 Family Project
#91
Well I got the front of the frame wire wheeled, primed and painted so it is starting to look good. I am thinking about pulling the motor mount brackets, which means cutting or drilling about 14 rivets.
I also got the cab all sanded down and ready for some temporary satin black. Temporary probably being for about 10-15 years.
Talk about a pain, just the top of the cab took almost 2 hours! That broom-painted white house paint is thick stuff!
I am hoping to get out there today and get the satin black sprayed on the cab. Then I have to clean out the garage because I got a nice thick layer of red dust on everything from all the sanding.
#93
It's a '49 F1.
I got the cab done with the satin black. I still have to do the passenger door, but at least the part I see the most is all one color.
It looks much better in the pics than in person because EVERY flaw, chip and sander mark shows through.
I just have to keep reminding myself that the goal is a running, driving truck that is all one color. After that I can worry about making her pretty.
#94
Just thought I would share a pic of my "new" front tires. I traded a CD player for a pair of 225/60R15's for the front of our truck. They are on 15X8 wheels.
I need to find some smaller center caps and some lug nuts, but the short/fat tires look great on the truck and give it a nice stance.
So can anyone tell me if you have to install longer studs to run aluminum wheels? The fronts are okay, but the rear lug nuts only grab about 2 threads on the studs. I am thinking I need to put in some longer wheel studs unless someone has a better idea.
#96
#99
Every time I do or say something that makes my wife shake her head I just tell her, "Hey, I'm twelve!".
#100
#101
Well today I ground and punched the rivets to remove the flathead mount crossmembers. Then I used an old wood chisel to scrape off all the undercoating. It wasn't as bad as I thought it would be and I am glad it was on there for the last 62 years because it kept my frame looking good.
Here is what it looked like before.
Here it is with a few coats of Krylon Semi-flat black (still wet in the pic).
Next will be to swap the front axle from my donor '52 that has new brakes. I am still working on finding mounts for the later OHV 6 cylinder from the '52.
#102
#103
I used an air chisel to cut the rivets out of what was left of the flathead mounts on my 50. I feel your pain there. The PO just used a torch to cut them off near the frame and that crossmember. It drove me crazy before I finally removed the cut ends. Also, I just finished removing SIX layers of paint from the cab of my 50. And I have driven myself crazy sandblasting and sanding with an air sander trying to get all those spots of paint completely off. You are indeed right, that primer will show you what you missed. Even the spots that felt smooth beforehand, it will just pull them up. Do you plan on lifting that cab and doing those frame rails or just getting what you can?
#105
- clean and paint the front of the frame while the front clip is off (DONE)
- swap front axles (current has a broken leaf spring and donor has new brakes).
- rebuild or replace master cylinder and get the brakes working
- install the engine and get it running
- reinstall the front clip
- drive it until next winter
The year after I will pull the cab and do the frame under it.
Eventually we'll put in a V8 (289,302, 351) with automatic and do the body work, but this is at least a 10 year project so just getting it running is our biggest goal.
