1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
replacing valve cover gaskets 1999 5.4 expy, anyone done this?
Old 10-07-2011, 01:57 PM
agexperts's Avatar
agexperts
agexperts is offline
Anyone know of a thread or done themselves?
Old 10-07-2011, 08:21 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Its a pain on the 5.4 driver side is pretty easy undo the harness from valve cover studs it pulls off, then disconnect the COPS and the injectors mark them if you need to set to side unbolt egr tube from valve and undo hoses from dpfe then unbolt egr tube from exhaust manifold ,you might need some jb blaster to get that off,unbolt oil tube from head remove cover and gasket ,replace gasket and grommets for studs ,dont forget a dab of gasket sealer at the seam where head and timing cover meet .....its the same for passenger side except the 42 pin connector is usually in the way, and undo the pcv hose ,trans fill tube,,,,FYI if you really want to make it easy and dont mind a little more work take out the wheel wells for wide open access
mhartiga1
1999 to 2016 Super Duty
12-19-2016 06:13 PM
Hotpocket
12-15-2011 08:09 PM
BFTUFF
1997 - 2003 F150
05-19-2011 09:48 AM
Shernius
1997 - 2003 F150
05-13-2010 07:18 PM
Quick Reply: replacing valve cover gaskets 1999 5.4 expy, anyone done this?
