No brake lights - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
No brake lights
Old 10-07-2011, 08:10 AM
handyman82801 handyman82801 is offline
handyman82801 is starting off with a positive reputation.
No brake lights
If this has been asked and answered I appologize for asking again. Don't get much time on my computer though.
99 E-350. No brake lights and can't shift from park. This should not be that complex of a circuit, but I'm at a complete loss of thought.
Thanks in advance for info.
Old 10-07-2011, 08:42 AM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
A sticky switch above the brake pedal shaft?
Old 10-07-2011, 08:52 AM
northwindone's Avatar
northwindone northwindone is offline
northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.northwindone has a very good reputation on FTE.
Quote:
I second that. Most automatics and manuals I've dealt with share 1 switch for the brake lights, cruise control cancel, and in automatics the shift safety interlock, or whatever it's called.
Old 10-07-2011, 09:01 AM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Did you check the fuse?
Old 10-07-2011, 03:07 PM
according to my dvm that switch is working ok. What else?
Old 10-07-2011, 03:25 PM
Which parts of the switch did you test. According to the diagram it is a two part switch. One part is brake lights, the other is other functions, including the shift interlock.
Old 10-07-2011, 04:39 PM
Not sure what the differance is but my switch only has 2 pins on it. I have since found that my 4 ways don't work either.
With 4 ways off my turn signals work. With 4 ways on they don't, I don't know if this is normal or not.
Old 10-07-2011, 04:41 PM
Are we talking about the same switch? It is where the brake pedal arm meets the brake master cylinder plunger under the dash.
Also are you sure you've checked all the fuses?
Old 10-07-2011, 05:51 PM
Same switch location mine only has 2 spade connectors on it. However I did find the problem.
It ended up being one of the fuses for the multi switch, had 12v on the brake pedal switch when depressed and still no brake lights, so I just started pulling fuses. Found one blown and replaced 4 ways started and brake lights also worked.
Thank you to all with answers.
Old 10-07-2011, 05:56 PM
jh818's Avatar
Hmmm.....sounds like a bad ground somewhere.
Old 10-11-2011, 08:38 PM
Where is the best place to find a fuse block chart for this van? The cover of the fuse block was missing when I bought the van. Without a diagram it is a little difficult finding the problem.
Old 10-11-2011, 08:48 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Quote:
Owner's manual. Go here Official Ford, Lincoln & Mercury Owner Site | Personalized Owner Information and look at the top of the page where it says "Vehicle Basics". There's a drop down menu there and you can select owner's manuals.
3rd brake light Edds 1978 - 1996 Big Bronco 4 01-16-2016 05:43 PM
no brake lights mike 1973 - 1979 F-100 & Larger F-Series Trucks 16 01-07-2016 09:56 PM
97 Expedition Parking brake light won't come on ACBreaker 1997-2006 Expedition & Navigator 3 02-16-2011 04:42 PM
Brake Question StanleyZ 6.4L Power Stroke Diesel 9 03-05-2010 06:41 PM
84 F250 Brake bleeding hugger94 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 11-14-2004 08:35 PM
Tags
05, 1994, 2004, 4x4, brake, colorado, diagram, duty, f250, ford, lights, parts, super, switch, test, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
