1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Shake while take-off and pulling heavy loads
Old 10-08-2011, 07:16 PM
Fred B's Avatar
Fred B
Fred B is offline
Smile Drive line shake
Hi,
Had the same problem with a 08 F 350 long bed diesel. Ford has a twix out saying that the driveline angle is changed when a heavy load is pulled. They shimmed my rear axel so there is limited shimmy under heavy load. You have to remember that if you shim too much it will vibrate and if you shim to little it will vibrate. A split drive shaft will solve the problem but that adds cost to a new truck.
Fred B
owenstout
05-12-2015 06:02 PM
machinegunted
07-16-2011 02:26 AM
Fluid Power
06-11-2007 11:41 PM
Skandocious
25
01-20-2007 10:01 PM
Godzilla250v10
08-09-2003 12:23 PM
Quick Reply: Shake while take-off and pulling heavy loads
