Shake while take-off and pulling heavy loads - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-08-2011, 07:16 PM
Fred B Fred B is offline
Fred B is starting off with a positive reputation.
Smile Drive line shake
Hi,
Had the same problem with a 08 F 350 long bed diesel. Ford has a twix out saying that the driveline angle is changed when a heavy load is pulled. They shimmed my rear axel so there is limited shimmy under heavy load. You have to remember that if you shim too much it will vibrate and if you shim to little it will vibrate. A split drive shaft will solve the problem but that adds cost to a new truck.
Fred B
98 ranger 4x4 violent shaking and loud clicking noises while coasting or braking at low speeds Ryno327 Ranger & B-Series 11 03-21-2017 11:33 AM
Chasing a bad vibration...getting scary! Zwalters 1999 - 2003 7.3L Power Stroke Diesel 57 10-31-2016 05:18 AM
Vibration 2003 4WD SD 6.0 oldman2003 1999 to 2016 Super Duty 4 08-26-2013 09:30 PM
Shaking under load Blmorre 1987 - 1996 F150 & Larger F-Series Trucks 7 12-28-2012 01:37 PM
4th Gear Light Throttle Shudder 7.3 Ex 1999 to 2016 Super Duty 2 03-13-2011 06:27 PM
Tags
04, boost, eco, end, f250, ford, heavy, it, load, pulling, rear, shakes, shaking, start, takeoff, taking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
