WTB 351M manual flywheel - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 10-06-2011, 09:04 PM
Khyren Khyren is offline
Khyren is starting off with a positive reputation.
As the title states. Need a good flywheel for the truck. PO used the one from the 360 parts truck and destroyed the bearings. Trying to fix the damn thing for winter. I'm located in North Central Ky. Would rather pick up than have shipped.
Old 10-07-2011, 01:40 PM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
How many you need? p/u?...I am in NJ
pm me if one of these interests you... just surface rust, been stored in the garage
Old 10-10-2011, 08:28 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
A 360's bolt pattern is different than a 351M-400 flywheel. The 360 flywheel shares the same bolt pattern as the 429-460 flywheel.
I have a 351M-400 flywheel out of a '79, it's drilled for a 12" long style clutch. PM me if it is what you need.
Old 11-30-2011, 02:13 PM
BRONCO2BCN BRONCO2BCN is offline
BRONCO2BCN is starting off with a positive reputation.
i have one out of 78f250 351m 50 bucks plus shipping.
WTB: 400m Manual Flywheel Joel Cassell WTB - Parts & other 1 08-23-2016 04:35 PM
400 Flywheel fords/harleys Clutch, Transmission, Differential, Axle & Transfer Case 0 12-16-2014 08:26 PM
79 460 with a 4spd manual flywheel ?? 78_f150 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 08-29-2013 12:44 PM
clutch and flywheel problems reecem13 Clutch, Transmission, Differential, Axle & Transfer Case 0 08-03-2008 10:51 PM
please help! Flywheel # ford_boy_1996 1987 - 1996 F150 & Larger F-Series Trucks 10 11-13-2007 09:15 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
302, 351, 351m, 360, 390, dimensions, engine, fe, flywheel, ford, manual, sale, usedford, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
