A tip for anyone changing the pushrod cover gasket on a 4.9.. - Ford Truck Enthusiasts Forums
Old 10-06-2011, 08:35 PM
slow3v's Avatar
slow3v slow3v is offline
slow3v is starting off with a positive reputation.
Holy crap what a pain getting it to seal! First time I did it, I tried dabbing RTV on the cover every few inches then placing the gasket on it.
FAIL.
Gasket fell off when putting the cover on, didnt even realize it until I realized I was dripping oil down the road and lost a little over 2 quarts today. (Did the gasket last night!)
Probably didn't help that I had tweaked the cover a little getting it back in. Regardless, this stuff worked GREAT. Extremely tacky, purpose made, and cheap. Put a small bead around the inside of the cover, set the gasket down and pressed it smooth. Bam, instant seal.
Highly recommend to make the job 100x easier.
Buy Permatex Ultra Rubber Gasket Sealant and Dressing 85409 at Advance Auto Parts
Old 10-06-2011, 09:31 PM
impalaslayer's Avatar
impalaslayer impalaslayer is offline
impalaslayer is starting off with a positive reputation.
Quote:
FAIL.
i had the same thing happen when i put mine on, it curled up inside and i didnt realize it.
Old 10-06-2011, 10:04 PM
slow3v's Avatar
Sucks having to tear something apart, AGAIN, but I'm glad it's all buttoned up.
Still have many things on my to-do list unfortunately.
No oil pressure! LPOP or something else? Bubba Jones 1994.5 - 1997 7.3L Power Stroke Diesel 10 04-24-2016 12:52 AM
Fuel filter housing leaking staarma Excursion - King of SUVs 4 04-28-2015 08:52 PM
92 4.0 X valve cover gaskets, Is it going to be expensive? 1998Ranger25L153CID Ranger & B-Series 2 10-13-2014 09:29 AM
Driver's Side Valve Cover Gasket cworley250sd 1997 - 2003 F150 2 02-18-2014 09:58 AM
Oil leak on a 300 dyoungen Ford Inline Six, 200, 250, 4.9L / 300 6 06-03-2013 06:15 PM
Tags
49, change, cover, cyl, f150, ford, gasket, inline, install, push, pushrod, replace, replacing, rod, stroked
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
