1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Hood won't open 03 F250 5.4
Old 10-06-2011, 07:04 PM
BBBSS's Avatar
BBBSS
BBBSS is offline
Went to do some work on the truck today and the freaking hood is locked up like a bank vault! Normally I could pull the hood pop and release it gently and walk over and yank the hood up. Wasn't working today so had someone help and hold it while I tried to pull it up but nothing. Even got some pliers and reached under the dash to pull on the wire some more thinking maybe it had too much slack but still nothing.
Not sure where to start with this one at this point?
Old 10-07-2011, 10:42 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Have you tried pushing down on the hood while someone pulled the lever?
I have to pull the lever, pick up on the hood and then release the latch under the hood.
Old 10-07-2011, 12:06 PM
northwindone's Avatar
northwindone
northwindone is offline
I had the same thing happen 2 days after I bought my truck. I thought the release cable had broke since the hood opened fine when I looked it before I bought it. I finally tried giving the hood a good shove downward and it popped up as usual when I let go. Hasn't done it since. Good luck, that can be very frustrating not being able to get your own hood open.
Old 10-07-2011, 06:58 PM
SDTriton250's Avatar
SDTriton250
SDTriton250 is offline
Been that long since the hood's been up? Gotta love that 5.4L Triton! I haven't raised my hood since the last oil change. Now you've got me scared! Other than that I ain't no help at all.
Old 10-07-2011, 07:47 PM
ItsMREMT's Avatar
ItsMREMT
ItsMREMT is offline
is the hood sitting level in the front? ( meaning is it resting on the hood stops in the front equally?)
53Mercdriver
07-14-2014 11:34 AM
fossilX
1997-2006 Expedition & Navigator
02-01-2012 10:42 PM
DS02F250
12-12-2005 01:01 PM
rushd
08-30-2003 08:20 PM
treebeard
1978 - 1996 Big Bronco
11-10-2002 06:26 PM
Quick Reply: Hood won't open 03 F250 5.4
