360 vs 361?
360 vs 361?
As far as actual cubves go they are exactly the same. Ford just threw the 1 on the end to signify it is an FT. The 361 had a forged steel crank with a larger snout. The block was stronger also. The heads are very restrictive. Do a search here for FE vs. FT or something and you will get tons of info.
360 vs 361?
Originally posted by chrowen
I was under the imoression that the 1 cube cam from the larger dish in the piston they used to reduce the compression from 8.6:1 down to 7.4:1. Maybe I am wrong.
Displacement comes from the swept volume of a certain bore size going a certain distance so the lower compression wouldn't change the displacement
360 vs 361?
I am not trying to be difficult, but explain one thing to me. I know the bore diameter or stroke length don't change, but there is still physically more volume inside the cylinder due to the larger dish on the head of the piston. Why doesn't that account for more cubic inch displacement? Maybe a better question is, what is the difference between static volume inside the cylinder and swept volume inside the cylinder?
I trust what you say; I just like to soak up as much input as I can get.
360 vs 361?
the compression of an engine is scalled by how much volume is squezed into a known amount of area. that is were you get 10 to 1 this means you are putting a certain amount of air fuel mixture into an area 10 times smaller hence 10 to 1.
cubic inch is the size of the piston and the distance that the piston travles to get it there, simply put, there is actually a mathematic equasion to help figure ci out wich I dont have at this time.
compression and cubic inch's are two different thing even though they can complement each other or hender each other.
Only cubic inches have Horse Power Potential, vrs compression.
360 vs 361?
Just to join in the fun, with the books I have on Ford engines, they say that the 390 and 391 / 360 and 361 have the same displacement and that the 1 was to distinguish between a motor used in a truck. Also, I have a friend that has a 390 in his dump truck so you have to know they will put out some tq.
That is my .02, but I'm still learning!!
