Surging/hesitiation at high vacuum conditions
Suspect is a 88 F-250 with a 5.8L engine. It has shorty headers and Taylor spark plug wires, both fairly new. Air pump removed by the PO.
Problem is when cruising at a steady speed the truck bucks, hesitates, surges, runs rough. If you press the gas pedal it goes away, runs fine. Idles fine, too.
Formerly it had a problem with stalling out when coming to a stop, but I discovered a vacuum leak at the plenum gasket, fixed this and the stalling went away. I went through the rest of the vacuum hoses, made sure everything was hooked up correctly and no leaks.
Problem happens more when the truck is warm. I replaced the ignition module and the problem went away for 2 trips, totaling about 30 miles, but suddenly started again. I have a pick-up coil to install, but haven't done so yet.
I've recently changed the fuel filter, the O2 sensor, and the spark plugs.
It didn't help at all. Only good news is it wasn't really that hard to change the pickup coil, only took about a hour to rebuild the distributor.
Koty Harley
24
06-01-2017 07:09 PM
68fish
08-22-2013 10:56 PM
dfwrider
01-01-2011 06:34 PM
NW 150
09-14-2010 03:27 PM
f-150_1993
46
07-15-2010 09:43 PM
