Cummins swap cost? - Ford Truck Enthusiasts Forums
Cummins swap cost?
Old 10-06-2011, 02:23 PM
Shawn66mcl's Avatar
Shawn66mcl Shawn66mcl is offline
Shawn66mcl is starting off with a positive reputation.
Cummins swap cost?
I have an 03 gas 250 and am looking at swapping in a cummins. I'm looking at getting a kit from ford cummins which cost about $3,000. Then I'll need to get a motor and rebuild the transmission. I'm figuring a total cost of around $10,000. Anybody who's done this swap, am I close or is my calculations way off? If it's over $10k, IO might just buy a diesel truck and use mine as a trade in.
Old 10-07-2011, 09:49 AM
LOP223 LOP223 is offline
LOP223 is starting off with a positive reputation.
It really depends on several factors. Are you doing ALL the work yourself? How much can you get the engine for? Did you account for all the things that doesnt come in the kit? With my experience on my swap $10k is on the low end, but I did alot of customizing as I went. I added go fast goodies and a dual disc clutch setup. I think it is possible, but you will have to get a good deal on the engine and watch the budget closely.
Old 11-07-2011, 08:25 AM
deck60's Avatar
deck60 deck60 is offline
deck60 is gaining momentum as a positive member of FTE.
cost
if you pick up a donor truck and can part it out that will make you cost significantly cheaper any way to make the cost cheaper I figure I will be about 2500-3000 out of pocket maybe less after I part out my parts truck
10k is doable but watch your pennies and use everything you can from the dodge
Old 11-17-2011, 10:53 AM
chocolatechip3512's Avatar
chocolatechip3512 chocolatechip3512 is offline
chocolatechip3512 is starting off with a positive reputation.
Engine Swap
I have a 1990 F-350, with a blown 7.3L engine, and found a 96 Dodge Cummins engine. How difficult is the swap, and can I keep my Ford manual tranny, and what else do I have to get? Please Help!
Old 11-17-2011, 03:29 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Get the NV4500, clutch etc from the Dodge. Ford trans is a ZF with integral bell, and isn't going to bolt up.
Old 11-20-2011, 06:15 AM
not enoughsmoke's Avatar
not enoughsmoke not enoughsmoke is offline
not enoughsmoke is gaining momentum as a positive member of FTE.not enoughsmoke is gaining momentum as a positive member of FTE.
Quote:
take my advise dont spend 3k from fordcummins i bought a tach kit and motor mounts and the only thing worth buying from them is the tach kit
there swaps stuff is not very professional really looks thrown together
stay away from the bellhousing adapters and run motstly dodge powertrain if you have any questions feel free i am on my second fummins already
Quote:
this is true having the ability to take ur time and do it all yourself will make it more appreciated
Quote:
run the dodge nv4500,nv5600 or the g56(not as good of a trans )
Quote:
it can be done with a adaptor plate
Old 12-06-2011, 06:08 PM
StealthWyvern StealthWyvern is offline
StealthWyvern is starting off with a positive reputation.
What auto trans would be best to run with the 4BT that will only do light towing at the most? I want to do this swap so I can enjoy my truck more on a daily basis.. Right now its just a backup that I drive on the weekends due to poor gas mileage.
I want to keep it auto mainly because it stays at my grandmas house and its her only source of transportation. I've only put roughly 8k on the truck in 6 years. lol The E4OD or whatever its called is well need of repair so might as well swap that out with something better if or when i do this. Yes Im aware the swap will set me back a good chunk of change.
Old 12-06-2011, 06:33 PM
47rh trans is all manual and holds up really good and simple
Old 12-07-2011, 04:58 AM
Quote:
Is it safe to assume that the trans will bolt right upto the 4bt? I didnt see any adaptor plates for this model.
Question for the guys that have done a fummins conversion uh60 1999 to 2016 Super Duty 0 10-30-2016 03:03 PM
Cummins swap Brianmb 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-29-2012 05:09 PM
1978 ford f-250 supercab cummins swap help Racer55 Engine Swaps 9 04-11-2012 06:06 PM
390 T56 powertrain route Stephen67 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 01-14-2012 08:47 PM
5R110 Swap jazz77 Excursion - King of SUVs 4 12-28-2011 12:38 AM
Tags
conversion, cost, cummins, duty, engines, expedition, f150, f250, ford, fors, obs, price, put, super, swap, total, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
