P1309 code comes back. - Ford Truck Enthusiasts Forums
Old 10-06-2011, 01:32 PM
CdnArmyGuy's Avatar
CdnArmyGuy CdnArmyGuy is offline
CdnArmyGuy is starting off with a positive reputation.
I have found many threads about a 1309 code. I had changed the CMP and Syncro, reset the PCM. Yes I used a Syncro tool. But after 60 Ks of driving check engine and the code comes back. Any thoughts?
Old 10-06-2011, 11:58 PM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
What year is your Explorer, and which engine does it have?
-Rod
Old 10-07-2011, 09:08 AM
CdnArmyGuy's Avatar
Its a 98, 5Lt
Old 10-07-2011, 11:12 PM
shorod's Avatar
So is it after 60k miles, or 60 kms, that the light came back on? The factory service manual suggests using a DMM (or scope) to backprobe the CMP sensor and confirm that over varying engine speed, the CMP output varies by more than 0.1Vac.
The manual continues to suggest that if the CMP voltage varies by more than 0.1Vac, replace the PCM. If not, replace the CMP. Did you happen to go with an OEM Motorcraft CMP sensor or an aftermarket?
-Rod
Old 10-08-2011, 11:34 AM
CdnArmyGuy's Avatar
After 60 Ks or so, Ive replace both the CMP and Syncro. The CMP was after market. Have not had anytrouble with after market before. What Im thinking is I should run a full restore cycle.
New Sport Warrior94 2015+ F150 4 10-18-2016 05:05 AM
Please help decifer codes crazy96863 Explorer, Sport Trac, Mountaineer & Aviator 9 11-30-2014 11:54 PM
1999 Ranger 6cyl 4.0L 4X4 Misfire dwollum Ranger & B-Series 2 04-13-2014 01:46 PM
Project Time Machine 1993 F-150 Flareside 4x4 Jefftopgun 1987 - 1996 F150 & Larger F-Series Trucks 15 10-16-2013 10:24 PM
P1309 still comes up 98 Expl 5 LT CdnArmyGuy Explorer, Sport Trac, Mountaineer & Aviator 1 10-02-2011 04:49 PM
Tags
1309, 2000, 2000fordexplorerp1309, 2001, 30, cde, check, code, econoline, engine, explorer, ford, misfire, p1309, pproblem, taurus, troubleshoot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
