Homemade cab stand or roller....?
Just curious, since you guys are helping me figure how to get the cab off, what type of stand (preferably a rolling stand), did you put your cab on once it is off the frame. Please show pics or plans if you have any....all suggestions are welcome. Thanks in advance. Phil.
I used a section of allthread to hold the corners together.
here is a pic with the cab sitting on it..
oh., make sure to get at least 2 locking casters.. this rolls pretty easy
u need the 4x6 to get the pallet high enough to allow your engine hoist under the stand.. else its a pain get the cab on/off
Sam
Cab Dolly
I opted for new 2x4s, a little glue, and some deck screws. I am not sure which version this one in the photo is but each time you build one (I think I am up to about #6) you improve upon it. I like everything on this dolly with the exception of the wheels, pneumatic tires don't want to swivel unless they are at a high air pressure. I use the larger (6 inch I believe) hard rubber casters now and they work great. I have found that using two non-swivel casters on one side makes the dolly a bit more stable...
Hey Phil,
One area to think through is the cab bracing. We just took the cab off & put in on a pallet without bracing it up - I guess it was in bad shape so it kind of sagged just a bit over time. We had it off for a couple of months. It was a major PITA to get it back square again - involving hydraulic jacks, etc. You may want to ask Sam & others how they brace their cab before taking it off - you will avoid a lot of unnecessary grief.
Ben in Austin
Ben in Austin
The following users liked this post:
Hey Phil,
Ben in Austin
Ben in Austin
I replaced the front cab floor and angled firewall section on this support..
(I did weld a crossbrace to the door posts first.)
Sam
I'm a big fan of bracing - It's all about what condition your cab is in - Your's is beautiful - mine not so much - that's the reason we had to take it off to address things. One pic below is the inside cab corners that were "holding up" the cab floor & their new replacements. The other pic is inside the driver's side footwell - had to add some bracing. If you have any question about the condition of your cab structure I'd try to keep it braced while moving it around.
Ben in Austin
Ben in Austin
Ben in Austin
Ben in Austin
Sam
There's one big problem with bracing...what geometry are you attempting to preserve? If the cab is tweaked to begin with, and many are right from the factory, then bracing merely preverves the misalignment. Cabs that are structurally unsound, either through rusted panels or panels that have been removed, need to be squared prior to assembly. If a person prefers to square the cab first, then brace to hold the dimensions, and then complete the repairs then that is great. OR you could remove the failed panels and square the cab as the repairs are made...this is much easier than trying to force the cab into square with porta-powers, etc. Before my cab was "beautiful" it looked like this...(see pic) as I replaced the floors and rockers I squared the cab. These cabs are made to "float" on hinged arms in the rear and rubber pads in the front...if they don't have their own structural integrity without bracing then they will never have it.
I really would like to see the dimension for this as a plan to build off. This is one of the best I have seen.
