Another hard shift thread - Ford Truck Enthusiasts Forums
Old 10-06-2011, 07:45 AM
79OldBone's Avatar
79OldBone 79OldBone is offline
79OldBone is starting off with a positive reputation.
So I picked up a 95 powerstroke last night for 2k to start my 79 body swap project with. Has 240k on it but the trans was rebuild in 08 and has all the papers to match. It shifts wicked hard tho. Puts your head right back back in the seat. BUT he said the speedo stopped working the same time it started shifting hard and the O/D Off started flashing. So from what I can tell that sounds like a VSS to me right? Thoughts?
Old 10-06-2011, 09:33 AM
79OldBone's Avatar
The odometer stopped working as well tho. I'm not sure if that would have anything to do with the vss or not.
Edit:
Also the dash lights from the speedo to the left died so you can only see the tach. All the other gauges themselves work tho. The left blinker light doesnt work on the dash either. I have read that a bad gauge cluster could do the same thing? Or does that just sound like a few lights out on the dash?
Old 10-06-2011, 10:15 AM
disco biscuit disco biscuit is offline
disco biscuit is starting off with a positive reputation.
Finally something I can comment on...yeah the tranny goes into limp and increases pressures to try to save the tranny. Runnin it like this will damage it. It will start leavin gears out of the sequence if you go too long
On mine I changed the sensor in the diff but after the speedo still bounced, it went right back to limp. The diff has a trigger ring attached, mine was damaged from a loose ring gear tooth. I went ahead and built the rearend. This trigger ring if flat in any spots will cause speedo/ shift problems
Old 10-06-2011, 10:36 AM
I gotta say after your edit...it does sound electrical. I'm not familiar enough with the specifics of the vehicle to tell you if the signal from vss goes through the ECU first or not.
Hell I should be...I've been chasing gremlins on the E-40 for awhile now. Mine hasn't been electrical though besides a few ratty connectors
Old 10-06-2011, 10:43 AM
79OldBone's Avatar
well what about the lights being out on the dash? is there a bulb behind it? or are the lights an integrated circuit in the dash?
Old 10-06-2011, 10:44 AM
79OldBone's Avatar
I also am not sure which sensor to buy. There are 2 and alot of ppl are saying that the 95's dont have the sensor in the transfer case. But I have an option of both of these.
Duralast/Vehicle Speed Sensor (SU1019) | 1995 Ford F250 3/4 ton P/U 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
Vehicle Speed Sensor | AutoZone.com
Old 10-06-2011, 10:47 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Lightbulb
Id recommend you to scan your truck to get codes
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
Look for a broken wire frame the frame to the VSS ..
Old 10-06-2011, 10:55 AM
79OldBone's Avatar
Quote:
Theres no check engine light tho? Wouldnt it come on if there was a code?
Old 10-06-2011, 11:00 AM
x2 on that deal friend. It's important to note not just any scanner will retrieve the tranny codes. I believe if you have a ford module type scanner it will do it...point is it's not a CEL.
I went through several friends who even had the model specific module. The one I found through process of elimination was the Snap-On Solarus. plus while he was there it ran good test on the rest of the systems...opened the waste gate on the turbo..
Also the visual look at the wiring from the axle all the way to the front is a good idea, as well as a jumper wire from front to back to check continuity with an ohmmeter.
Like his signature says but slight variation:
If you can't fix it with a hammer you got an electrical problem
Old 10-06-2011, 11:02 AM
The tranny on these models throws separate from the ECU....I knew you would ask that, see my above post.
I gotta go back to studying Diesel specifics
Old 10-06-2011, 11:17 AM
RÖENTGEEP's Avatar
FOREIGN GURU
Talking
You wrote: the O/D Off started flashing. thats a reason to get codes.
Old 10-06-2011, 11:38 AM
79OldBone's Avatar
Alright, I have a buddy who works at the local ford dealership. When I get home I will see if he'll run down. I'll buy the sensor anyways tho since its only $20 and try it.
So true or false tho... the 95 only has the VSS in the rear axle? Why is there 2 options of one that looks like it goes in the transfer?
Also if the gauge cluster is messed up I have a buddy with a 91 cab. Will that gauge cluster work in my 95 gas or diesel? The wait to start is in the dash itself not the cluster.
Old 10-06-2011, 01:36 PM
Leemakesmepee's Avatar
Leemakesmepee Leemakesmepee is offline
Leemakesmepee is starting off with a positive reputation.
Not sure if its the same. but my dads 95 f150 gasser`s speedo went out and it started ****ting really hard. We replaced the vss and did a tranny flush but it turned out being the speedo breaking. not sure if its the same on our trucks. just an idea.
Old 10-06-2011, 03:32 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
If you've got bulbs out, then go ahead and replace them. All you have to do is pull the trim pieces, unhook the little cable that changes your transmission range indicator, and then pull out the instrument cluster. I just took the whole thing to a parts store and they hooked me up with the proper bulbs. It's a night and day difference.
E40D shifting ungodly hard srsparky32 1987 - 1996 F150 & Larger F-Series Trucks 31 11-01-2016 09:51 PM
Shift Problems 94 F150 4x4 Tripletkennels85 1987 - 1996 F150 & Larger F-Series Trucks 5 10-14-2012 07:45 AM
HARD SHIFTING AUTOMATIC RANGER, HELP!!!! daniel5625 Ranger & B-Series 0 01-21-2011 05:25 PM
Transmission hard shifting mikew72 1999 to 2016 Super Duty 5 10-24-2005 09:13 AM
'92 F150 E4OD Trans shifting hard problem 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 10 06-03-2005 09:46 PM
Tags
1996, body, escape, ford, hard, jump, location, powerstroke, rough, shift, shifting, su1019, swap, truck, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
