Another hard shift thread
alright, so I will try the speed sensor first tonight. Seams to fit the symptons: O/D blinking, no odometer, no speedo but everything else works.
Again so theres only ONE speed sensor on the 95 correct?
This one?
http://www.autozone.com/autozone/par...er=F85Z9E731AB
NOT this one:
http://www.autozone.com/autozone/par...ier=68815_0_0_
This one?
NOT this one:
I should note I'm a new guy and I have the same flashing od light which still hasn't been resolved. I have solved my vss problem, or trigger ring in diff on ring gear which led to fixing other code eliminations. Now Im chasing the ill fated Torque Converter lock code.
Point is I didn't want to give impression I solved it completely kinda felt I made it seem that way...
I have spent countless hours chasing this crap(3 yrs off and on...mostly off) during this time I have spent more time reading my Ford specific shop manual and thousands of threads...no exageration, this is the only place I thought worth joining. I've read more than a prisoner in for life.
Your problems lie in your instrument cluster...buy a whole new one. You can't service the speedo pack itself, it has to be done all together. If no fuses are blown and wiring is in good order, I guarantee a light isn't your problem.
My code reads to be torque converter, yours should read something to do with speed. You can check the vss it is a known problem...mine was the trigger ring on the ring gear. But thank yourself for editing in the gauge problem(very important info)
Read the code for sure but you need a new gauge cluster. If it was the sensor the speedo would bounce...the odo wouldn't be totally out
Yeah so heres the scoop. I changed the VSS last night with high hopes but no luck. I knew as soon as I turned the truck on and still no odometer. I found a few guys who will sell me gauge clusters for $40 and $50. I dont care what it has for miles on it. As I wont be selling the truck def any time soon if ever in my lifetime. I hope its not my ring. I did look in the hole when i had the sensor out and it looked like a sprocket from a dirtbike but it seamed okay? not that I'd be able to tell if it was warn.
Soo I guess thats the next step is to pull the gauge cluster. How do I go about this (again new to fords). I started to pull the plastic off but on the left side it was hung up on the headlight switch and I didnt know how to pull that **** off. I tried to twist it and pull on it but without know which way it comes off for sure I didnt wanna force it. Then the right side doesnt seam to want to unclip. Is there something more to it? In highschool I had a 99 F150 and it all just popped off easy.
Once the dash is apart I imagine its just a few screws and the cluster is out. Then can I just unplug one cluster and plug the new cluster in and be ready to rock n' roll?
I'm not a "expert" but a good friend of mine used a gauge cluster out of a gas. I hope you don't get mad at me but finally got mine fixed. The Torque Converter clutch code and subsequent flashing O.D. button was caused by the brake light on the back of the cab. I don't know if I'm pissed or ecstatic, I know it caused me to drink whiskey which could be either emotion. I'm stuck in trouble shoot mode. These emotions may be caused by a secondary fault in the emotion circuit...Pain in my a^#
I'm starting a flashing O.D. light thread to blab all the problems I encountered while chasing this and others for 3yrs. Please feel free to post on there...I may put a link to your thread if you don't mind---if I can figure out how
#30
ha! well my cab light works but my speedo and odometer tells me mine is more but congrats of the ending of your headache! haha So he used the gasser gauge in the powerstroke and it all worked fine? No issues with the computer or trany? What year is his powerstroke and what year did he get the cluster from? Any ideas? Thanks
Just trying to figure out what year dash's will work. The older ones has 2 speed sensors but Im not sure if the dash's were the same or not?
