1976 ford f100 charging issues - Ford Truck Enthusiasts Forums
Old 10-06-2011, 12:30 AM
1976flareside 1976flareside is offline
1976flareside is starting off with a positive reputation.
my 1976 f100 has a 302cid which is not the stock motor but im told had no problems before the previouse owner parked it two years ago. i purchased the truck about a month ago and the battery will not stay charged while its running. i replaced the alternator and the battery holds a good charge as long as its not running. ive checked all the grounds and traced all the wiring back as far as i can go. Any ideas or advice that anyone has would be great, thank you
Old 10-06-2011, 07:31 AM
nlareau's Avatar
nlareau nlareau is offline
nlareau is starting off with a positive reputation.
Can't say what's wrong with yours, but I can tell you what was wrong with mine. That 45 Amp alternator just wasn't cutting it with the radio, radiator fans, and everything else. I was driving down the road with a working alternator and still drawing down on the battery.
A junkyard 3G alternator as people describe here was the smartest, easiest upgrade I've done to this truck. $20.
Old 10-06-2011, 10:16 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Does this truck have an ALT light, or an ammeter gauge in the dash? There are a few wiring items to check first; if they check out then the regulator is suspect.
Old 10-13-2011, 04:34 PM
i do have an ammeter and i have an ambulance grade alternator but if i disconnect the neg- battery cable while its running the engine dies, and i just took the alternator down and napa tested it for me and it read out good
Old 10-13-2011, 04:43 PM
Quote:
"This truck will do the speed limit on the trailer to the scrap yard"
Old 10-13-2011, 06:23 PM
kingford72's Avatar
kingford72 kingford72 is offline
kingford72 is starting off with a positive reputation.
check the fusible link that comes from the alt harness to the battery side of the starter sel.
Old 10-13-2011, 09:47 PM
fmc400's Avatar
MSEE
Never disconnect the battery from a running engine. If you do this, the alternator output can jump very high, and fry any onboard electronics like CB radios, ignition modules, etc - in some cases even burn out bulbs.
Check the fusible link in between the alternator output and the battery-side of the starter solenoid for continuity. If that's fine, then have the regulator tested.
Charging and Running Problems 1978FrankenFord 1973 - 1979 F-100 & Larger F-Series Trucks 25 04-04-2016 09:26 AM
1976 f100 restore? fordf10076 1973 - 1979 F-100 & Larger F-Series Trucks 37 07-08-2015 12:49 PM
1976 keeps dying rthomas1963 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-17-2015 08:35 PM
Alternator on my 1976 302 in my 1956 F100 Quiff_boy_Elvis 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 01-04-2014 03:49 AM
Charging Issue tylert1976 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-31-2013 03:38 PM
Tags
1973, 1976, 390, alternator, charging, connection, diagram, f100, ford, forum, problems, replace, system, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
