Torn at how big to stroke the 351W...?
I am not sure how big i want to take the 351W i have in my 95' lightning. I am not a guru in the pros and cons of these motors. Any suggestions? I hear 408 is prob the best medium as it provides some more stability and longevity vs a 427 but is this true? Any input would be great.
My goal is to put 450hp-550hp to the tires. Tq will come with the build no matter what. Right now i am pretty sure it is all stock on internals. Just bolts ons like headers, intake, i do not think it uses stop ECU but the previous owner has given me no input on what is under the hood, he says e never touched the motor. Which i cannot say he did or not but it has alot of pep in it's step for just bolt ons it seems like. Speed limiter is still set to 95 so i am pretty sure it is stock.
Some discussion here:
351W Stroker; 393 vs 408 | Mustang Forums at StangNet
393 is cheaper, using stock rods and 302 pistons.
FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines - Ford Stroker Kits :: Coast High Performance Rotating Assemblies :: 351 Windsor Stroker Kits
A 427 can be done with a stock block but the stronger set up is an aftermarket block. Lot$ o'dollars...
Your goal of 450-550 hp at the rear wheels would be easier to get if you start with a 460 based engine.
Going to build a 427 stroker from a 351W, any help? - Ford Mustang Forums
8LugSlug
24
06-02-2011 09:07 PM
matpasch
06-10-2010 07:25 PM
shazam
09-23-2003 06:11 AM
