What is this sensor? - Ford Truck Enthusiasts Forums
Old 10-05-2011, 09:14 PM
Blue86's Avatar
Blue86 Blue86 is offline
Blue86 is starting off with a positive reputation.
The engine is a 1992 4.9L. I'm putting it into my '86 F150. I haven't found the map sensor harness yet so I was leaning towards that.
Old 10-05-2011, 09:59 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
You know, I have that same connector lying around ***** nilly too....Not hooked up..Just lying there...
Btw...The Map sensor has a vac/ line to it...
Old 10-05-2011, 10:01 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
That's for the flux capacitor.
Actually I have no idea, but i wanted to bump to the top for more helpful people.
Old 10-05-2011, 10:13 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
It's been a while since I had a 300 apart, but I seem to remember that harness running down between the intake runners to something under the manifold. Can't remember exactly what though.
Old 10-05-2011, 10:20 PM
I honestly have no idea either...So I simply laid it off, that if 2 300's had it, and wasn't plugged up...It was a spare connector, or it was for something the truck didn't come with....
Blue86's Avatar
Hahaha! Thanks.
Old 10-05-2011, 10:50 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
It's probably a plug to retrieve data and diagnose the injectors, not a sensor (just a guess, but it does look like that).
Old 10-05-2011, 11:05 PM
Blue86's Avatar
Quote:
You're thinking about the EEC connector. That's mounted on the firewall near the master cylinder.
Old 10-05-2011, 11:23 PM
Quote:
I'm sure Encho knew that...But I also think he may be onto something...Considering that, the injectors are the ONLY electrical things within reach of that connector...Maybe some sort of secondary diagnostic tool...
Old 10-06-2011, 04:55 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
I think that is for the canister purge valve. The valve is located in the vacuum line between the throttle body and the carbon canister and will sit near that plug on top of the lower intake manifold runners.
Old 10-06-2011, 05:56 AM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
As stated above, that's for the optional Flux Capacitor. There were only 3 trucks that left the factory with this option installed. You happen to be the proud owner of one of those 3.
You'll have to build a new Flux Capacitor, since Doc Brown is stuck in a different, alternative time period and is unable to help.
But today is your lucky day!! I located a DiY Flux Capacitor instructional web page. You'll have to upgrade the nuclear device located above the spare tire mount to accept garbage to make it work...but I'm sure you have the intelligence to do it. DIY Flux Capacitor
If you are able to make it work, go back to 5/7/1993 and force me to leave with you and talk some sense into me...I don't want to make the mistake of marrying that psycho woman.
Old 10-06-2011, 06:11 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
That should be the plug for the fuel rail cooling fan to prevent vapor locking on the 4.9L engine.
Old 10-06-2011, 07:31 AM
kd0axs's Avatar
Quote:
I forgot about this. Neither my 93 or 95 300s had this. IIRC, on the newer models, they got rid of the fan and raised the fuel pressure to prevent vapor lock. I'm thinking this means that he is also going to need the newer fuel pump for the 92 engine to run properly in his 86 truck.
Old 10-06-2011, 05:31 PM
EPNCSU2006's Avatar
There's not a fuel rail cooling fan on a '92. I'm reasonably certain that connector fits the canister purge valve - only reason I'm not 100% is I haven't had a look under the hood of my dad's truck in a while (also a '92 w/ the 300).
Old 10-06-2011, 09:17 PM
subford's Avatar
Is the plug from the 86 or the 92 engine harness?
1978 F150 5.3 LM7 Swap Rossta86 Engine Swaps 44 12-27-2016 06:33 PM
86 ranger not firing injectors spooktn Ranger & B-Series 6 08-29-2016 11:50 AM
Do I have a bad PCM??? Ezalycasaid 1994.5 - 1997 7.3L Power Stroke Diesel 27 08-28-2016 07:19 PM
Fuel Pressure Sensor pre or post filter? Sous 1999 - 2003 7.3L Power Stroke Diesel 37 12-10-2015 12:08 PM
tone ring install in 86 8.8 flcracker9 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-09-2014 09:05 AM
Tags
1978, 351m, 49l, clogged, cylinder, emissions, excursion, f150, ford, fuel, master, rail, sensor, sensors, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
