1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Lengthen wheelbase, extend frame
Old 10-05-2011, 09:01 PM
Sparky04SD's Avatar
Sparky04SD
Sparky04SD is offline
I'm considering having my frame lengthened to increase the wheebase from the present 141" to either 161" or 176", both are stock Ford SD wheelbase options. I really need a flatbed for hauling rather then my present pickup shortbox. The truck is a F250 SD 4x4 in my signature. I would consider trading in if they still sold 6 speed manuals and V10's in a 250/350 package. My present truck only has 41k miles. Is cutting the frame in half and adding in a section a bad idea? I've seen it done on much bigger trucks with no problems.
Old 10-05-2011, 09:20 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
It can be done. The most important thing is that it is done right. Its not unheard of, but unless you are VERY confident in your skills, I would take it to a body shop (or if youre lucky to have one around, a specialized frame/chassis shop). Its not abnormal for a good body shop to do something like that.
Old 10-05-2011, 10:06 PM
Sparky04SD's Avatar
Sparky04SD
I have NO intentions of doing this project myself. I intend to find a good shop with the experience to do this project. I want it done correctly the first time.
Old 10-05-2011, 10:09 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Thats the right attitude. In that case, yes it can be done, and fairly reasonably. You have already decided to use a factory offered wheel base, so that is good. It will make things easier.
Old 10-05-2011, 10:38 PM
Sparky04SD's Avatar
Sparky04SD
I figure if I use a factory wheelbase option I can use all stock Ford driveshaft lengths as well as brake lines, possible wiring and fuel line/tank setups if needed. I want this to look totally factory done as much as possible. My goal is to mount a 9-10' flatbed on it.
Old 10-05-2011, 10:51 PM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
Other possibility's for shops to lengthen the frame include tow truck dealers (they lengthen and shorten all the time) and commercial welding shops.
Old 10-05-2011, 11:06 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Good point. Any upfitter shop should be able to do it no problem.
Old 10-05-2011, 11:34 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
as far as I know no welding shop is allow to touch vehicle suspension and frame parts unless they have special license to do so.
Old 10-06-2011, 12:15 AM
jh818's Avatar
jh818
jh818 is offline
Could you get a Ford frame in the length you're looking for and swap it with your current frame along with the longer parts you need? Cutting and welding just seems to be a lot of work. Plus having to be within Ford's spec. and properly welded with the right extensions, rust proofing, etc.
What is the cost of the frame compared to cutting and welding?
Edit: Thought about what I mentioned above some more and there would be quite some work also to swap the frame. Pulling the engine, trans, cab and all. ???
If you pull everything off, you get to swap out body mount bushings and mounts with new ones.
Old 10-06-2011, 12:24 AM
maverick22's Avatar
maverick22
maverick22 is offline
Can it be done? Sure, no doubt. But there's more parts to consider than just splicing in a new piece of steel and fish plating it. Call around and get some quotes, if anyone would even do it, I have to think it would be either cheaper or the same price to just trade your truck and buy what you want. You could get the manual and v10 up until 2010.
No body shops around here would even fathom doing something like that, a truck fab shop might and they're the experts on stretching frames b/c they do it on big trucks all day. There's a lot of differences between a mack and a superduty though. Most important thing - they don't work cheap and this isn't a small project.
Old 10-06-2011, 12:26 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
If you go to the right place its not very expensive. As previously mentioned an upfitter shop can do it no problem. Its what they do.
The following users liked this post:
Old 10-06-2011, 01:39 AM
Sparky04SD's Avatar
Sparky04SD
Maverick22:
If you can show me a SuperCab 6 speed V10 F250/350 4x4 with manual transfer case (under 60k miles) for sale someplace with an 8' bed I would be interested in buying it. I've scoured the US with no luck.
Old 10-06-2011, 02:05 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Originally Posted by Sparky04SD
Maverick22:
Not sure what you're looking for in the way of creature comforts but here's a 2006 V10 4WD manual shift Supercab long wheelbase with a utility body and only 29,961 miles on it and it's got the manual transfer case.
2006 FORD F250 for sale in Lima, Ohio - Commercial Truck Trader
If you're not looking at Lariat trim levels and only need a good work truck, this should fit perfectly. Plus, if you wanted to put a flatbed on it, you could sell the utility bed and recoup a little of your investment.
Old 10-06-2011, 02:09 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
Maverick22:
2005 F350 V10 4x4
Old 10-06-2011, 02:13 AM
powerstroke72
Quick Reply: Lengthen wheelbase, extend frame
