Magnets in oil and tranny pan?
Would it cause any issues if I were to buy a couple of really strong magnets to put in my oil pan and transmission pan? I am not sure if there are any types of magnets that would interfere with my electronics if the magnets were made of a certain type of material or if they were too strong.
Thanks.
Thanks.
Our DD 1999 Buick also has a factory donut magnet.
I did put one in my C6 pan earlier this year when I dropped it.
Not a good idea putting one in your engine pan though. No way to access it after to clean it etc.
They sell these magnets you slide on your oil filter though. You can go that route.
Also... There are hundred of transmissions out there with the donut magnet in them. The concept is not new.
Best thing to do for the oil is get a magnetic drain plug. Then you can clean it off every time you change the oil.
You can buy aftermarket magnet kits that are designed to install in the lifter valley and other areas of the engine. They used to be fairly common in race built engines, maybe they still are.... The goal is to catch pieces and parts of components in the event of failure and keep them from going through the entire engine and causing more damage.
My dad used to put magnets in the oil pan of almost every motor he had. He used livestock magnets sourced from the local Vet or farm supply store. They are pretty strong, but small and pill shaped to allow the cattle to swallow them. They are perfect for inserting them through the oil drain hole during an oil change. Once the metal shavings stick to the magnet, it's almost impossible to get them off. I can't see where it would cause any issues, even if you don't have access to it for cleaning.
Personally, I like the magnets that attach to the outside of the oil filter. Simple, effective, re-usable and you get rid of the metal shavings when you change the filter.
The more I think about it, the best option would be to put some magnets around the oil filter (suggestion by someone else on this post). First reason is because the oil filter is removable and this can allow for the trapped metal to be removed from the oil much sooner than when the oil pan is dropped. The second reason is that the all oil is designed to circulate through the filter so this acts as a central point. If I have a magnet strong enough, it should capture everything. That seems like the best of both worlds.
cPath_1_15 | products_id_1 | Neodymium Motor Magnets 1 Pair 1.5" OD x 1.25" ID x 3/4" 90 Deg - Applied Magnets & WindMax Wind Turbines
There are also "filtermags" for you "high dollar ballers" out there that want to drop $30-$60 for a curved magnet that sticks to the outside of your oil filter to pull metal shavings out. I have seen rebuilders drop a 3-4in donut magnet into the oil pan. It won't hurt anything... I like the idea of putting a magnetic drain plug in to catch the little magnet shavings but I use the dorman EZ drain plugs (tool-less oil changes are quicker and easier!). Anyway, I'd never take the plug out to clean it. But if I got into the bottom end of an engine of mine, I'd drop a magnet in for sure! The only risk you'd be taking is if the magnetic would at some point spontaneously de-magnetize and release all the little metal bit back into the engine, and that's a little far fetched for me.
Any which way you want to go... it's always a good idea to pull extra junk out of your oil!
couple options for those reading this thread. the filtermag option claims to reduce the particle filtration rating on your filter to 1 micron!
Filtermag RA365 Oil/Fluid Filtration Magnets
Amazon.com: Hardline Products 1336 Magna Guard Black Oil Filter Magnet: Automotive
for bottom of oil pan or maybe insid if you wanted...???
