What did you use.......?
on
while i used a cherry picker to lift mine off, one way that might work if the cab is stripped and the frame is able to roll is to put some 2x4's or 2x6' under the cab then lift it high enough to clear the frame and roll the frame out from underneath. i would lift the cab up and then support the ends of the boards on either some drums or sawhorses. one person might even be able to do it this way as you only have to lift one side at a time. secure the cab to the boards with some lag bolts so they don't move.
that is my idea.
Rgds
Mike
that is my idea.
Rgds
Mike
https://www.ford-trucks.com/forums/1...-the-body.html
Like Mike said, If your chassis is a roller, you don't need to get it all up in the air at once; you raise a corner, crib it, until it's supported by boards straddling the frame, then roll the frame out.
I third that. The 4x4 I used had to be as far forward in the door openings as I could get it. I also used a cinder block inside and all the way back/center to level it out. I had some other crap in there too, but I can't tell ya what.(can't remember now.)
Like some of the others, I used my engine hoist for cab lifts on my current '41 project. I too needed to maximize the height of the lift. So I used a pair of 12" long 2x6's sandwiched on either side of the main lift arm (with a 1/2" bolt securing it to the arm) and attached to a pair of 2x4's that span the width of the cab. The added height helped and I adjusted (shortened) the main lift arm a notch to gave a more stable lift of the cab. Very handy ... no more "cab lift parties" required.
