How do you remove a factory stereo from a 2003 Explorer?
Old 04-08-2003, 08:28 AM
RecklessAbandon's Avatar
RecklessAbandon
RecklessAbandon is offline
My parents own a 2003 Ford Explorer Limited, and though it's a very nice unit already, I'm wanting to replace it with a Pioneer motorized, flat-screen TV/DVD/CD unit. I've had the Ford factory stereo removal tools from previous stereos we have removed on our older Fords, but the new unit doesn't have the holes to insert the tools, nor any screws on the panel surrounding the stereo.
I was wondering how to get the stereo out exactly. We bought a Hayes repair manual, but doesn't show anything about removing it. Does the surrounding dash moulding just pop off with a screw driver or anything? And once you get the dash apart, how do you remove the stereo? Will there then be the four holes exposed to use the tools, are do you need some other tools?
We have the new installation kit and head unit ordered for the vehicle, just don't know how to get the factory unit out. If someone could please help me out I'd really appreciate it.
Much thanks,
Andrew
Old 04-08-2003, 09:01 AM
ricki621's Avatar
ricki621
ricki621 is offline
It is not that hard to remove the stereo, although not as easy as the old removal pins. The large plastic surround trim must be removed first. It is on VERY securely and is held by 4 metal spring type clips and two other studs for a total of six mounting points. Use a putty knife with electrical tape over the end and start at the bottom, close to one end and pry it up. Once you get one loose, the others will also release as you get under them. Once this is loose, the 4WD selector simply unplugs and the panel is clear. Then there are two obvious metal bolts right in front securing the stereo in the dash. It pulls right out from there.
KhanTyranitar
Aerostar
54
05-31-2020 11:33 AM
Andy47130
02-18-2016 06:30 PM
Matt M, PA
02-13-2016 09:35 AM
-*o*- REWASDRTY
1999 to 2016 Super Duty
15
03-01-2010 05:08 PM
RecklessAbandon
1997-2006 Expedition & Navigator
04-23-2003 05:48 PM
Quick Reply: How do you remove a factory stereo from a 2003 Explorer?
