How do you remove a factory stereo from a 2003 Explorer? - Ford Truck Enthusiasts Forums
Old 04-08-2003, 09:28 AM
RecklessAbandon RecklessAbandon is offline
RecklessAbandon is starting off with a positive reputation.
My parents own a 2003 Ford Explorer Limited, and though it's a very nice unit already, I'm wanting to replace it with a Pioneer motorized, flat-screen TV/DVD/CD unit. I've had the Ford factory stereo removal tools from previous stereos we have removed on our older Fords, but the new unit doesn't have the holes to insert the tools, nor any screws on the panel surrounding the stereo.
I was wondering how to get the stereo out exactly. We bought a Hayes repair manual, but doesn't show anything about removing it. Does the surrounding dash moulding just pop off with a screw driver or anything? And once you get the dash apart, how do you remove the stereo? Will there then be the four holes exposed to use the tools, are do you need some other tools?
We have the new installation kit and head unit ordered for the vehicle, just don't know how to get the factory unit out. If someone could please help me out I'd really appreciate it.
Much thanks,
Andrew
Old 04-08-2003, 10:01 AM
ricki621 ricki621 is offline
ricki621 is starting off with a positive reputation.
It is not that hard to remove the stereo, although not as easy as the old removal pins. The large plastic surround trim must be removed first. It is on VERY securely and is held by 4 metal spring type clips and two other studs for a total of six mounting points. Use a putty knife with electrical tape over the end and start at the bottom, close to one end and pry it up. Once you get one loose, the others will also release as you get under them. Once this is loose, the 4WD selector simply unplugs and the panel is clear. Then there are two obvious metal bolts right in front securing the stereo in the dash. It pulls right out from there.
How to upgrade the stock sound on an Aerostar KhanTyranitar Aerostar 51 03-23-2015 07:51 PM
!996 Explorer remove instrument cluster Ford_NDN Explorer, Sport Trac, Mountaineer & Aviator 2 03-25-2010 01:12 PM
99-04 Easy Stereo Swap and Fender Badges -*o*- REWASDRTY 1999 to 2016 Super Duty 15 03-01-2010 06:08 PM
04 Explorer Head Unit Removal viper48220 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 03-01-2004 12:57 PM
Removing existing rear TV/DVD system from a 2003 Expedition. RecklessAbandon Expedition & Navigator 6 04-23-2003 06:48 PM
Tags
2002, 2003, 2005, dash, explorer, factory, ford, mountaineer, radio, removal, remove, removing, sport, stereo, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
