Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-05-2011, 12:38 PM
pit_of_pity's Avatar
pit_of_pity pit_of_pity is offline
Garage is empty, add now
pit_of_pity is starting off with a positive reputation.
Dollar bill trick & a burned valve?
I've been chasing my issue with a 360 rough idle for quite a while. I held the dollar bill next to my passenger side exhaust and it was getting sucked in = burned exhaust valve. I did a compression check and cylinder #1 read 70psi, cylinder #4 read 95psi and rest were 120-125psi. No oil is being burned. All I know is the the previous owner had the timing all f'd up until I bought the truck 2.5 years ago and got it tuned right. I did the the dollar bill test a year ago and did not see any issues. Otherwise the truck runs fine and does not miss at any speed.
1: Is this issue prone to develop into a major issue until I tear into it (few months) and can it lead to a disaster meanwhile. I need to drive it up 200 miles this weekend.
2: I do not trust any of the local mechanics in Brooklyn (from what I've seen most are just knuckleheads that just create further damage). I would rather pull the heads myself, ship them off for a valve job/rebuild and install them myself. Is there a specific procedure to rebuilt head installation specific to valve rocker/pushrods? Can I put everything in the same order?
Thanks for the help
  #2 (permalink)
Old 10-05-2011, 06:27 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
1976 Ford F-250
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
I drove 2 years and 8000 miles with a cracked exhaust valve in #3 cyl. on my last 360. lol It did slowly get progressively worse. As in the tick got louder and the compression on that cylinder got lower. I wouldn't recommend going that long but I knew I was going to go full rebuild when it came time anyway. If you take it easy, no high revs and such, I think you'll be ok.
When you install the fresh heads everything goes back in the same order but you'll need to check pushrod length and valve clearance. I'd recommend an adjustable pushrod so you can easily determine what length you'll need when checking clearances. That'll make sure you only buy pushrods once. This is the way the Ford manual recommends checking with non-adjustable rockers. Lifter preload and valve clearance
You'll need Ford tool T58P-6565-A to bleed down the lifters. Or you can just get a set of adjustable rockers and set to "0" lash and back off 1/2 a turn. It might be a good idea to check the suspected burnt valve to make sure it's still in proper clearance until you can fix it. You don't want it out of spec and "pounding". That could lead to the valve breaking.
__________________
Jeremy
1976 F250 4x4 Ranger XLT. 445FE, NP435/205, D44/60 4.10
AKA the never ending project.
  #3 (permalink)
Old 10-06-2011, 08:18 AM
69cj 69cj is offline
69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of69cj has much to be proud of
Would be nice to know the year and motor your running. If an early FE make sure you have hardened valve seats installed .
__________________
"05 F-250, 6.0, CC, LB, 3.73, 4 X 2, Lariat, with coolant filter and Bilstein shocks, Magnefine p.s. filter, Ford fuel press. spring upgrade and ScanGauge ll. S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
2007 FHLP H.D. Road King
2007 Thor Jazz 5er, 11k dry weight, 31'
173rd Abn. RVN.
  #4 (permalink)
Old 10-07-2011, 11:02 AM
atom bomb atom bomb is offline
atom bomb is starting off with a positive reputation.
How does the dollar bill trick work? Do you hold the dollar at the tailpipe?
I'm guessing that with dual exhaust, you have 4 cylinders pushing exhaust out, so if one exhaust valve is burned you will get a vacuum every 4 pulses but not a constant vacuum? Is this correct?
Atom
  #5 (permalink)
Old 10-07-2011, 11:12 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to allmikeo0o0o0 is a name known to all
Atom
Pretty much, it's an old mechanic's trick. With everything firing right, the dollar bill is blown out like it was being pushed by a fan. If one cylinder is misfiring, that creates a reversion wave in the exhaust and the bill will want to get sucked towards the tailpipe whenever that cylinder fires...or in this case misfires.
  #6 (permalink)
Old 10-07-2011, 12:12 PM
Good to know. I'm a mechanic and didn't even know that one. Many thanks!
  #7 (permalink)
Old 10-07-2011, 01:55 PM
mikeo0o0o0's Avatar
Welcome to FTE, stick around and you'll learn a lot of the old tricks that mechanics have used over the years.
There are a lot of good people here more than willing to answer any questions you might have.
  #8 (permalink)
Old 10-07-2011, 02:23 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
That's a good one to use, but try a compression test for more certain results.
  #9 (permalink)
Old 10-10-2011, 08:30 PM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
Quote:
This check has never failed me. I just used it on a coworker's 3yr old ride. I couldnt tell him exactly which cylinder, until I read his codes. Two cylinders were mis-firing intermittently. Botom line, it was a blown head gasket between both cylinders.
  #10 (permalink)
Old 10-15-2011, 01:17 AM
Quote:
Absolutly, I would also add a pressure leak down test. A compression test will isolate the problem to certain cylinder, a leak down test will isolate the loss of compression to the exhaust\intake valve or the rings in a cylinder.
  #11 (permalink)
Old 10-26-2012, 08:30 AM
eallanboggs eallanboggs is offline
eallanboggs is starting off with a positive reputation.
Now you can do a cranking compression(relative compression) test WITHOUT removing any spark plugs using an oscilloscope and a clamp on current probe. You hook the clamp on probe around the heavy gauge red or black wire going to the starter or block. These two wires carry all the current the starter uses to spin the gas engine. That's ch1 on the scope. Ch2 goes around an ign or inj wire for #1 cy to sync off of #1 cy so you know which cy is misfiring based on the firing order which you already have memorized, right? Crank the engine and look at the waveform shape which should look like a bunch of camel back humps lined up in a row. If a hump is not as high as the others the compression is lower(not as much current needed to spin that cy). That's when you get out the leak down tester for the one cylinder that was low(relative to the others). Alternately you could put a pressure transducer in that bad cy and crank the engine over and watch the waveform again. Based on a good waveform(iATN)you can tell which stroke of the 4 stroke cycle is malfunctioning. It's like magic.
  #12 (permalink)
Old 10-26-2012, 01:30 PM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
Quote:
oh man...that's nice.
__________________
'65 Galaxie 500, 390 auto
'65 F100, 300 straight 6
'79 F250, 460 C6
Tags
428, 429, 46, aerostar, bill, burnt, dollar, exhaust, fix, ford, treating, trick, valve, valveon, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
