Somebody at Ford is my Damn HERO!!!!
Old 10-05-2011, 08:53 AM
housedad's Avatar
housedad
housedad is offline
As part of designing all the mods I want to make, I need to make a 2 inch hole in the firewall for the 22 pin bulkhead connector and to review what changes to the power wires that would be done.
Weather Pack 22 position bulkhead connector kit DIYAutoTune.com
So I was pouring over the engine compartment. (laying literally accross the engine) and I noticed something that I never did befor.
Just to the fender side of the brake vacuum booster on the firewall is a large foil sticker.
When I started looking at it, it turned out to be a stick on weeathercover for a hole in the firewall.
A BLESSED 2 INCH HOLE!!!!! IN THE PERFECT PLACE!!!
It is accessable from the inside. The firewall soundpadding inside already has a die cutout for this. I just had to cut three small tabs that held it in.
The location also has two holes for mounting a bulkhead connector, but they are too large and far away for the Delphi unit. It will require drilling two SMALL holes for the mounting bolts only.
I could KISS the engineer at Ford right now that left that in there.
(and no, I did not cut through the foil yet....)
Old 10-05-2011, 09:14 AM
nnak58's Avatar
nnak58
nnak58 is offline
I used that hole for my wiring for my lighting. It works great. It's there for the manual transmission superduty's for the clutch pedal linkage and reservoir.
Old 10-06-2011, 12:17 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
i knew about this because when i do snow plow installs on super dutys it comes in very handy! pisses me off they have made it about a 1/2" hole 2011-up
Old 10-06-2011, 01:35 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I think what you are talking about is the hole for the clutch pedal shift linkage.
This is what mine looks like. Could be different since you have an 05
Old 10-06-2011, 05:24 AM
housedad's Avatar
housedad
housedad is offline
Yep, that's the place. In my 05, though, I don't have the plastic. it is just a layer of really heavy foil tape type material.
All this time and I never knew about it. sheesh.
Old 10-06-2011, 07:41 AM
ljhedrick's Avatar
ljhedrick
ljhedrick is offline
Would someone be willing to take a photo of the location from inside the cab? I tried to run a wire for my Maxbrake controller and could not find a hole to use. I ended up running it through the fender and in through the hole that is used for the door wiring. It works but I would rather use a hole in the firewall.
Old 10-06-2011, 11:01 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Lucky for you I read your post at my truck and I can post photos on the go
Carbonarc
06-05-2019 09:30 AM
Rembrant
04-13-2019 08:43 PM
RIPbiker13
07-23-2018 08:54 AM
Force21
08-10-2013 02:13 PM
99 sd v10
1999 to 2016 Super Duty
03-07-2004 12:58 PM
Quick Reply: Somebody at Ford is my Damn HERO!!!!
