Input on putting rear F350 leaf springs in the back of my F150 - Ford Truck Enthusiasts Forums
Old 10-04-2011, 11:04 PM
jsalveson's Avatar
jsalveson jsalveson is offline
jsalveson is starting off with a positive reputation.
OK, has anybody done this? I have some leaf springs out of a 93 F350 Dually. How much lift would this give me? How bad would this effect the ride? Any and all input is appreciated.
Old 10-04-2011, 11:36 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
I've put F350 springs in an F250. I had to get different driveshafts, shocks, and the stock Ubolts were JUST long enough. The ride even from the 3/4 ton to the 1 ton suspension really stiffened up noticeably. Im guessing that you may end up with about 6 inches of lift maybe? I got 4 inches of lift on a 3/4 ton so it must be a hair more.
Old 10-04-2011, 11:52 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
If you have false teeth, you better stock up on Polygrip!!!!!!!
Old 10-05-2011, 12:01 AM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
How about this?
But in all seriousness, don't forget putting a 1 ton spring pack, sure it might give you more loading capacity, but then again not really. You still have the rather weak half ton semi-floating 8.8" axle witch is no bullet proof axle...
Plus, F250/350 springs are an inch wider.
I drove a long time ago a boxless F350 with a bigger leaf pack than my motorhome in that pic, and I swear I ran over a dime and can tell what date was on it!
Old 10-05-2011, 12:27 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
are you just looking for lift? if so you might want to look into a shackle flip to avoid an overly stiff suspension. sell your tonners on craigslist to fund the parts and be money ahead!
Old 10-05-2011, 07:48 AM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
Shackle flip isn't that to lower?
Old 10-05-2011, 08:11 AM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
3/4 and 1 ton springs are the same width as 4x4 1/2 ton springs.
Old 10-05-2011, 08:30 AM
Slowroll90 Slowroll90 is offline
Slowroll90 is starting off with a positive reputation.
It should work fine, as mentioned before. A bit stiff
Also won't increase load capacity because other components still haf ton
Block kits are cheap if you just want lift
Old 10-05-2011, 08:32 AM
Yes but with block kits you can get some serious axle wrap. I know from experience.
Old 10-05-2011, 10:09 AM
jsalveson's Avatar
I did the shackle flip and got about 2 1/2 inches. I still need another 3 inches. I'm not worried about load capacity. I have some blocks that I am trying to avoid using.
Old 10-05-2011, 11:53 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Hate to brake it to you but 3/4 and 1 ton springs are the SAME THING. So you either didnt have 3/4 springs in your truck or you didnt put 1 ton springs in.
The only difference between the rear suspension of a f250 and F350 is the 2.5" block on a F250 and 4" block on a f350. Both a 5 leaf springs
THAT IS IT. NOTHING ELSE
And to the OP, unless you want to add weight carrying capacity to your F150 you would be foolish to put 350 spring in. Ditch you F150 block(2") and put in a F350 block(4")
Old 10-05-2011, 12:07 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
When I had my 95, I went to the junkyard and got some springs out of an F-250. They had 6 leaves in each side, mine had 5. Turns out I couldn't get the bolts out of the ends, so I dissected the leaf packs and added 2 leaves on each side. That gave me about 2.5" of lift. It rode like a hay wagon, but I filled the bed up completely with black dirt and it sat perfectly level.
I also had front coils out of an E-350 van and a 3" body lift. I had 35" tires on it.
Old 10-05-2011, 12:38 PM
CJM8515 CJM8515 is offline
CJM8515 is starting off with a positive reputation.
Just put an extra leaf in it, putting 350 springs wont work allt o well-they are wider.
F150 uses 2.5" springs, F250/350 uses 3" wide springs.
Old 10-05-2011, 10:55 PM
jsalveson's Avatar
No actually 4X4 F150s use 3" springs. Only the 2wd F150s have 2.5" springs.
Old 10-05-2011, 11:02 PM
jsalveson's Avatar
Quote:
Diesel_Brad- Thank you once again. You really know your stuff.
Thanks everyone for the help.
Front Leaf Spring Installation help granny_rocket 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-18-2015 08:33 PM
leaf springs countrysF250 Brakes, Steering, Suspension, Tires, & Wheels 0 09-09-2013 07:46 PM
1 ton leaf springs into a 4x4 f150? akuhr93'f150 1987 - 1996 F150 & Larger F-Series Trucks 13 10-04-2012 08:19 AM
Rear leaf springs TruckNorris 6.0L Power Stroke Diesel 2 03-20-2012 12:46 PM
leaf spring hanger andyj ford driver 1987 - 1996 F150 & Larger F-Series Trucks 18 10-01-2011 01:03 PM
Tags
1993, 1997, 2002, 2010, bracket, capacity, difference, f150, f350, ford, leaf, rear, spring, springs, stock, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
