Dual fuel tank install with selector - Ford Truck Enthusiasts Forums
Old 10-04-2011, 05:31 PM
Kert0307's Avatar
Kert0307 Kert0307 is offline
Kert0307 has a good reputation on FTE.Kert0307 has a good reputation on FTE.Kert0307 has a good reputation on FTE.
I wanted a little more time between fill ups mainly for convenience on long trips. I picked up a 5th wheel style aluminum tank off craigslist and went to work. I cut the bottom out of the tool box to add a the 55 gallon aluminum fuel tank. I used a fuel tank selector switch kit made for the 1997 and previous Ford Pre-Super Dutys (it is a tank selector kit including valve with return line ports, switch, and wire harness with instructions) so I can now select between the two tanks (stock fuel gauge shows level for tank that is being used). This gives me a new highway running distance of about 1500 miles or 1100 mile city between fill ups unloaded...
Inside the tool box
Classy selector valve shield I made to protect it from road debris.
Selector switch that came with the kit, doesn't really match the dash, but works and is factory labeled main and aux.
Old 10-04-2011, 05:41 PM
Kert0307's Avatar
Link to selector I used
| O'Reilly Auto Parts
Old 10-04-2011, 08:59 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
a few things you should know.
dot says you can not dirrectly feed a carb or injector.
next you can not transport more then 85 gallons accross state lines
Old 10-04-2011, 09:24 PM
Larry00663 Larry00663 is offline
Larry00663 is starting off with a positive reputation.
Since the fuel pump is located inside the main fuel tank, how is the added tank going to supply fuel to the engine?
I have an older Ford with dual tanks but the fuel pump is engine mounted.
Old 10-04-2011, 09:25 PM
Crash16 Crash16 is offline
Crash16 is gaining momentum as a positive member of FTE.
He should be right at the 85 gallon limit if I'm thinking right. Almost all 6.0 psd's came with a 30 gallon tank, am I right?
Old 10-04-2011, 09:26 PM
cheezit's Avatar
on all the powerstrokes the pump is frame mounted and is basicly insiide the frame under the drives door.
as long as you are using the oem pump you should be good this will keep the ineratia swich still as a safty devise.
Old 10-05-2011, 09:29 AM
Kert0307's Avatar
Yes, I am using the stock fuel pump. I spliced into the stock fuel lines on top of the factory tank (they are a lot smaller than I expected). I was under the impression that as long as I stayed under 110 gal in the bed of the truck, it would be DOT compliant. Either way, since it is hidden, I'm not worried about being pulled over for it.
Old 10-05-2011, 10:36 AM
Dial911's Avatar
Dial911 Dial911 is offline
Dial911 is starting off with a positive reputation.
I installed a 50 gallon aux tank in my bed with this transfer kit:
RDS Diesel Install Kit for Auxiliary Diesel Fuel Tank — Fits 1999–Current Ford, Dodge and 2011 Chevrolet and GMC Trucks, Model# 011025 | Auxiliary-Transfer Tank Accessories | Northern Tool + Equipment
It gravity feeds to the stock filler neck (the aux tank just keeps the main tank topped off until empty). Been in the truck for over a year without issue. No extra pumps, no wiring and no switches to install in your truck.
Old 10-05-2011, 11:07 AM
Kert0307's Avatar
I've seen that kit, but I like the idea of having the tanks completely separate. I'm not crazy about that gravity fill system. I'm glad it's working out for you though.
Old 10-05-2011, 06:56 PM
cheezit's Avatar
I used the rds setup as well . the gravity feed works great.
2007 F-350 crew cab stereo build mooch91 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 71 11-18-2012 10:54 AM
Few new gauge pictures... CSIPSD 1999 - 2003 7.3L Power Stroke Diesel 29 05-21-2012 08:16 PM
Sticker / Logo POLL - VOTE NOW! SDElwood Michigan Chapter 38 06-19-2011 03:24 PM
Toolbox with custom tonneau cover in progress Kert0307 1999 to 2016 Super Duty 10 06-02-2011 09:28 AM
"Barn Find" 1943 Ford G8T 1.5 Ton Military rwhite07PSD 1947 and Older Ford Trucks 4 05-10-2009 01:10 PM
Tags
1980, alternative, chevy, diesel, dual, ford, fuel, gas, installation, put, selector, tands, tank, truck, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
